NSO Kubernetes Lab
791
NOTE: This is WIP, and I'm aiming to have this hosted on dCloud as a hands on lab. Stay tuned!
The aim with this lab is to build a Kubernetes (k8s) cluster with three nodes. In this cluster we will install NSO, one master and two slaves. Using these we going to experiment with leader election and fail over.
The master node (kube-1) is hosting the bulk part of the k8s machinery, i.e. API, controller and scheduler. In a production environment, you will typically not schedule any pods on the master node. For this lab we'll remove that restriction and use the master node as well.
The first test will not have persistent storage for NSO, so if all pods die, all data is lost. We will therefore move on to install a persistent storage provider (GlusterFS) on all three nodes. With this in place, we will setup NSO again, but now on persistent storage. Leader election and failover will still work as before. But now we can take an outage of all three NSO pods.
Credentials
The nodes are called kube-1, kube-2 and kube-3.
Kube-1 will serve as as the k8s master.
Credentials
The credentials on the nodes are:
username: test
password: cisco123
Install Kubernetes on Three Nodes
SSH to the Master Node (kube-1)
ssh test@X.X.X.X
Initialize k8s on the master node
Make sure docker is working and can pull images
test@kube-1:~$ docker run --rm -it alpine:latest /bin/sh
Unable to find image 'alpine:latest' locally
latest: Pulling from library/alpine
8e3ba11ec2a2: Pull complete
Digest: sha256:7043076348bf5040220df6ad703798fd8593a0918d06d3ce30c6c93be117e430
Status: Downloaded newer image for alpine:latest
/ # exit
Next we're going to use kubeadm to setup the master node, later followed by the slave nodes.
Sometimes kubeadm times out when downloading the images, therefore it's a good idea to pull the images first. Please run the following until all images are pulled.
test@kube-1:~$ kubeadm config images pull
[config/images] Pulled k8s.gcr.io/kube-apiserver-amd64:v1.11.2
[config/images] Pulled k8s.gcr.io/kube-controller-manager-amd64:v1.11.2
[config/images] Pulled k8s.gcr.io/kube-scheduler-amd64:v1.11.2
[config/images] Pulled k8s.gcr.io/kube-proxy-amd64:v1.11.2
[config/images] Pulled k8s.gcr.io/pause:3.1
[config/images] Pulled k8s.gcr.io/etcd-amd64:3.2.18
failed to pull image "k8s.gcr.io/coredns:1.1.3": exit status 1
If you get an error as above, please run again.
[config/images] Pulled k8s.gcr.io/coredns:1.1.3
Pod Networking
When installing k8s, you have a wide variety of pod networking to choose from. For the lab, we've decided to use Flannel (https://github.com/coreos/flannel). "Flannel is responsible for providing a layer 3 IPv4 network between multiple nodes in a cluster. Flannel does not control how containers are networked to the host, only how the traffic is transported between hosts."
To install k8s, we'll use the kubeadm init command, and since we're going to use Flannel as our pod network, we will pass the 10.244.0.0/16 CIDR to kubeadm. This means that our containers will end up with 10.244.x.y addresses.
test@kube-1:~$ sudo kubeadm init --pod-network-cidr=10.244.0.0/16
[init] using Kubernetes version: v1.11.2
[preflight] running pre-flight checks
I0820 14:49:38.345563    5854 kernel_validator.go:81] Validating kernel version
I0820 14:49:38.345804    5854 kernel_validator.go:96] Validating kernel config
[preflight/images] Pulling images required for setting up a Kubernetes cluster
[preflight/images] This might take a minute or two, depending on the speed of your internet connection
[preflight/images] You can also perform this action in beforehand using 'kubeadm config images pull'
[kubelet] Writing kubelet environment file with flags to file "/var/lib/kubelet/kubeadm-flags.env"
[kubelet] Writing kubelet configuration to file "/var/lib/kubelet/config.yaml"
[preflight] Activating the kubelet service
[certificates] Generated ca certificate and key.
[certificates] Generated apiserver certificate and key.
[certificates] apiserver serving cert is signed for DNS names [kube-1 kubernetes kubernetes.default kubernetes.default.svc kubernetes.default.svc.cluster.local] and IPs [10.96.0.1 10.0.0.4]
[certificates] Generated apiserver-kubelet-client certificate and key.
[certificates] Generated sa key and public key.
[certificates] Generated front-proxy-ca certificate and key.
[certificates] Generated front-proxy-client certificate and key.
[certificates] Generated etcd/ca certificate and key.
[certificates] Generated etcd/server certificate and key.
[certificates] etcd/server serving cert is signed for DNS names [kube-1 localhost] and IPs [127.0.0.1 ::1]
[certificates] Generated etcd/peer certificate and key.
[certificates] etcd/peer serving cert is signed for DNS names [kube-1 localhost] and IPs [10.0.0.4 127.0.0.1 ::1]
[certificates] Generated etcd/healthcheck-client certificate and key.
[certificates] Generated apiserver-etcd-client certificate and key.
[certificates] valid certificates and keys now exist in "/etc/kubernetes/pki"
[kubeconfig] Wrote KubeConfig file to disk: "/etc/kubernetes/admin.conf"
[kubeconfig] Wrote KubeConfig file to disk: "/etc/kubernetes/kubelet.conf"
[kubeconfig] Wrote KubeConfig file to disk: "/etc/kubernetes/controller-manager.conf"
[kubeconfig] Wrote KubeConfig file to disk: "/etc/kubernetes/scheduler.conf"
[controlplane] wrote Static Pod manifest for component kube-apiserver to "/etc/kubernetes/manifests/kube-apiserver.yaml"
[controlplane] wrote Static Pod manifest for component kube-controller-manager to "/etc/kubernetes/manifests/kube-controller-manager.yaml"
[controlplane] wrote Static Pod manifest for component kube-scheduler to "/etc/kubernetes/manifests/kube-scheduler.yaml"
[etcd] Wrote Static Pod manifest for a local etcd instance to "/etc/kubernetes/manifests/etcd.yaml"
[init] waiting for the kubelet to boot up the control plane as Static Pods from directory "/etc/kubernetes/manifests"
[init] this might take a minute or longer if the control plane images have to be pulled
[apiclient] All control plane components are healthy after 40.001870 seconds
[uploadconfig] storing the configuration used in ConfigMap "kubeadm-config" in the "kube-system" Namespace
[kubelet] Creating a ConfigMap "kubelet-config-1.11" in namespace kube-system with the configuration for the kubelets in the cluster
[markmaster] Marking the node kube-1 as master by adding the label "node-role.kubernetes.io/master=''"
[markmaster] Marking the node kube-1 as master by adding the taints [node-role.kubernetes.io/master:NoSchedule]
[patchnode] Uploading the CRI Socket information "/var/run/dockershim.sock" to the Node API object "kube-1" as an annotation
[bootstraptoken] using token: pahwji.frci87slyux729v0
[bootstraptoken] configured RBAC rules to allow Node Bootstrap tokens to post CSRs in order for nodes to get long term certificate credentials
[bootstraptoken] configured RBAC rules to allow the csrapprover controller automatically approve CSRs from a Node Bootstrap Token
[bootstraptoken] configured RBAC rules to allow certificate rotation for all node client certificates in the cluster
[bootstraptoken] creating the "cluster-info" ConfigMap in the "kube-public" namespace
[addons] Applied essential addon: CoreDNS
[addons] Applied essential addon: kube-proxy
Your Kubernetes master has initialized successfully!
To start using your cluster, you need to run the following as a regular user:
  mkdir -p $HOME/.kube
  sudo cp -i /etc/kubernetes/admin.conf $HOME/.kube/config
  sudo chown $(id -u):$(id -g) $HOME/.kube/config
You should now deploy a pod network to the cluster.
Run "kubectl apply -f [podnetwork].yaml" with one of the options listed at:
You can now join any number of machines by running the following on each node
as root:
  kubeadm join 10.0.0.4:6443 --token pahwji.frci87slyux729v0 --discovery-token-ca-cert-hash sha256:8fdd45a2a0004788cde9c6b89fcdec56931fcda1c74322ac7bccfa6f88a14ee2
Now get kubectl into the user's home directory
test@kube-1:~$ mkdir -p $HOME/.kube
test@kube-1:~$ sudo cp -i /etc/kubernetes/admin.conf $HOME/.kube/config
test@kube-1:~$ sudo chown $(id -u):$(id -g) $HOME/.kube/config
If we check the nodes, we'll see our master node, but it's not ready. To fix that, we need to install a pod network..
test@kube-1:~$ kubectl get nodes
NAME      STATUS     ROLES     AGE       VERSION
kube-1    NotReady  master    33s       v1.11.2
Install Flannel
To install Flannel we simply apply the YAML provided by the Flannel project:
clusterrole.rbac.authorization.k8s.io/flannel created
clusterrolebinding.rbac.authorization.k8s.io/flannel created
serviceaccount/flannel created
configmap/kube-flannel-cfg created
daemonset.extensions/kube-flannel-ds-amd64 created
daemonset.extensions/kube-flannel-ds-arm64 created
daemonset.extensions/kube-flannel-ds-arm created
daemonset.extensions/kube-flannel-ds-ppc64le created
daemonset.extensions/kube-flannel-ds-s390x created
After Flannel is installed, you should shortly see the master node coming up
kube-1    Ready     master    21m       v1.11.2
Allow scheduling on the master node
To allow scheduling of workloads on the master node, we need to untaint it.
test@kube-1:~$ kubectl taint nodes --all node-role.kubernetes.io/master-
node/kube-1 untainted
If we don't do this, no pods will be scheduled on the master node. In a production system this makes sense, but for this lab we want to use all three nodes.
Add Slave Nodes
Next thing is to add our two slave nodes, kube-2 and kube-3, to the k8s cluster.
The kubeadm init command for kubeadm will print a join command that can be used by the slaves, but you can also generate a new one:
test@kube-1:~$ kubeadm token create --print-join-command
kubeadm join 10.0.0.4:6443 --token w23h6m.ze6f4j7c0xanskd2 --discovery-token-ca-cert-hash sha256:bbb0d19cdc33a13db449121676326dcf5b140925bc0ab973365d5a17b7158008
NOTE: You cannot copy the join commands from here, you have to generate your own as explained above or copy the one outputted by the kubeadm init command.
NOTE: You have to do the following on both kube-2 and kube-3.
SSH to kube-2 and kube-3
test@kube-1:~$ ssh kube-2
test@kube-2:~$ sudo kubeadm join 10.0.0.4:6443 --token qohtw7.ufsn3xma6imzj80n --discovery-token-ca-cert-hash sha256:4629539b
39ea7f7663e80fc2ea902a7b39e467df396d848c4242c13088ad61a2
I0821 09:28:45.475918     673 kernel_validator.go:81] Validating kernel version
I0821 09:28:45.476369     673 kernel_validator.go:96] Validating kernel config
[discovery] Trying to connect to API Server "10.0.0.4:6443"
[discovery] Created cluster-info discovery client, requesting info from "https://10.0.0.4:6443"
[discovery] Requesting info from "https://10.0.0.4:6443" again to validate TLS against the pinned public key
[discovery] Cluster info signature and contents are valid and TLS certificate validates against pinned roots, will use API Server "10.0.0.4:6443"
[discovery] Successfully established connection with API Server "10.0.0.4:6443"
[kubelet] Downloading configuration for the kubelet from the "kubelet-config-1.11" ConfigMap in the kube-system namespace
[tlsbootstrap] Waiting for the kubelet to perform the TLS Bootstrap...
[patchnode] Uploading the CRI Socket information "/var/run/dockershim.sock" to the Node API object "kube-2" as an annotation
This node has joined the cluster:
* Certificate signing request was sent to master and a response
  was received.
* The Kubelet was informed of the new secure connection details.
Run 'kubectl get nodes' on the master to see this node join the cluster.
test@kube-2:~$ exit
Please redo the same for kube-3.
After a while the new nodes should come up
kube-1    Ready     master    59m       v1.11.2
kube-2    Ready     <none>    35m       v1.11.2
kube-3    Ready     <none>    36s       v1.11.2
We now have a working k8s cluster.
Create a local Docker registry
We're going to push our containers to a local registry, this will speed up and simplify things when we build our own NSO containers.
To start the registry, on kube-1:
test@kube-1:~$ docker run -d -p 5000:5000 --restart=always --name registry registry:2
To test the docker registry, first pull an image from Docker Hub
test@kube-1:~$ docker pull alpine:latest
Status: Image is up to date for alpine:latest
Next, let's tag it for our local registry
test@kube-1:~$ docker tag alpine:latest kube-1:5000/alpine:latest
Now push it into the registry
test@kube-1:~$ docker push kube-1:5000/alpine:latest
The push refers to a repository [10.0.0.4:5000/alpine]
73046094a9b8: Pushed
latest: digest: sha256:7e8e16517347ec0b19fac1700682cc0b905b4c10d91a5f409452d2327fe49b8d size: 528
To make sure we can pull from our registry, we'll remove the local image
test@kube-1:~$ docker rmi kube-1:5000/alpine
Untagged: kube-1:5000/alpine:latest
Untagged: kube-1:5000/alpine@sha256:7e8e16517347ec0b19fac1700682cc0b905b4c10d91a5f409452d2327fe49b8d
Deleted: sha256:11cd0b38bc3ceb958ffb2f9bd70be3fb317ce7d255c8a4c3f4af30e298aa1aab
Deleted: sha256:73046094a9b835e443af1a9d736fcfc11a994107500e474d0abf399499ed280c
Then we pull it back
test@kube-1:~$ docker pull kube-1:5000/alpine:latest
latest: Pulling from alpine
f031366bd5fe: Pull complete
Digest: sha256:7e8e16517347ec0b19fac1700682cc0b905b4c10d91a5f409452d2327fe49b8d
Status: Downloaded newer image for kube-1:5000/alpine:latest
All good!
Create NSO base image
We're going to create an NSO base image that we'll base the project image on. This is not necessary, but I've found that it saves time during development to have a base image onto which I install the NSO project.
Go the the k8s-lab/base-container directory, where you'll find a number of files, the most interesting files is the Dockerfile.
It will install a couple of packages needed by NSO. It also installs curl which will be helpful later on.
FROM ubuntu:16.04
COPY nso-4.6.1.3.linux.x86_64.installer.bin /tmp/nso
RUN apt-get update; \
    apt-get install -y openssh-client default-jre-headless python curl; \
    /tmp/nso /app/nso; \
    echo '. /app/nso/ncsrc' >> /root/.bashrc; \
    apt-get -y clean autoclean; \
    apt-get -y autoremove; \
    rm -rf /tmp/* /var/tmp/* /var/lib/{apt,dpkg,cache,log}/
EXPOSE 8080 830 2022 2023 4569
It installs NSO in /app/nso and cleans up after apt. Last it exposes a number of ports that NSO uses.
To build and push the image to the local registry please run (NOTE, this can take a couple of minutes).
test@kube-1:~$ ./build.sh
Sending build context to Docker daemon 188.5 MB
Step 1/4 : FROM ubuntu:16.04
---> 7aa3602ab41e
Step 2/4 : COPY nso-4.6.1.3.linux.x86_64.installer.bin /tmp/nso
---> Using cache
---> 5a3f5d3eb822
Step 3/4 : RUN apt-get update;     apt-get install -y openssh-client default-jre-headless python git curl;     /tmp/nso /app/nso;     echo '. /app/nso/ncsrc' >> /root/.bashrc;     apt-get -y clean autoclean;     apt-get -y autoremove;     rm -rf /tmp/*
Successfully built a35fb1e9e6d3
The push refers to a repository [kube-1:5000/nso-base]
6b7ec8654278: Pushed
869384c52942: Pushed
bcff331e13e3: Pushed
2166dba7c95b: Pushed
5e95929b2798: Pushed
c2af38e6b250: Pushed
0a42ee6ceccb: Pushed
latest: digest: sha256:bbd34574f8af11322ce726d160f48bb9766367d9ebcdd8aece8629bfd1f6f0d6 size: 1783
NSO Container
Next we will build our NSO container that contains the packages we use for this test. Please navigate to k8s-lab/nso-container
This Dockerfile is quite simple, just adding the NSO project to the base container.
from kube-1:5000/nso-base
COPY nso-app /app/nso_project
COPY run-nso.sh /.
EXPOSE 4570
ENTRYPOINT ["/run-nso.sh"]
To build, simply run
Sending build context to Docker daemon     64kB
Step 1/5 : from kube-1:5000/nso-base
---> 7c3dc8b25152
Step 2/5 : COPY nso-app /app/nso_project
---> cec6b567551b
Step 3/5 : COPY run-nso.sh /.
---> c671eee6e239
Step 4/5 : EXPOSE 4570
---> Running in f8c5440dd665
Removing intermediate container f8c5440dd665
---> 53814cc9fce8
Step 5/5 : ENTRYPOINT ["/run-nso.sh"]
---> Running in 51cc1c16771a
Removing intermediate container 51cc1c16771a
---> f1dd50c21e62
Successfully built f1dd50c21e62
Successfully tagged kube-1:5000/nso-k8s-lab:latest
The push refers to repository [kube-1:5000/nso-k8s-lab]
c8c8f4c5557e: Pushed
7f37e62a2dda: Pushed
e291435ad52b: Mounted from nso-base
4458e05c75c6: Mounted from nso-base
d7232280c8c4: Mounted from nso-base
07663827a77f: Mounted from nso-base
87a2d0000622: Mounted from nso-base
4a7a5ec0f29e: Mounted from nso-base
8823818c4748: Mounted from nso-base
latest: digest: sha256:3a80da141f03dc3205c91d9afec2c7606edaa5d19acaa951c434ef7a6bcf2ab9 size: 2199
Now we have the NSO container we'll use for the rest of the lab.
NSO Service and RBAC
To access NSO we'll create a couple of k8s services, we'll also install a k8s role for leader election.
Please go to the k8s-lab/nso-service directory
We will register two services for NSO, please see nso-service.yml
kind: Service
apiVersion: v1
metadata:
spec:
  clusterIP: None
  ports:
  - protocol: TCP
    port: 8080
  selector:
    app: nso-app
kind: Service
apiVersion: v1
metadata:
spec:
  ports:
  - protocol: TCP
    port: 2024
  - protocol: TCP
    port: 8080
nso-svc
The service will service all NSO instances and could be used for RO access, port 8080 is exposed.
nso-svc-master
This service will service only the NSO HA master and will expose ports 8080 and 2024.
To get leader election to work, we also need to give the default user access to k8s endpoints, please see rbac.yml
# Create role to allow user to read endpoints
kind: Role
apiVersion: rbac.authorization.k8s.io/v1
metadata:
  namespace: default
rules:
- apiGroups: [""] # "" indicates the core API group
  resources: ["endpoints"]
  verbs: ["get", "watch", "list", "update"]
# This role binding allows "default" to read endpoints in the "default" namespace.
kind: RoleBinding
metadata:
  namespace: default
subjects:
- kind: User
  apiGroup: rbac.authorization.k8s.io
roleRef:
  kind: Role
Make sure you apply both these files
test@kube-1:~$ kubectl create -f nso-service.yml
service/nso-svc created
service/nso-svc-master created
test@kube-1:~$ kubectl create -f rbac.yml
role.rbac.authorization.k8s.io/endpoint-reader created
rolebinding.rbac.authorization.k8s.io/read-endpoints created
Make sure the services are registered
test@kube-1:~/nfs/kube-ha/k8s-lab/nso-service$ kubectl get svc
NAME             TYPE        CLUSTER-IP      EXTERNAL-IP   PORT(S)             AGE
kubernetes       ClusterIP   10.96.0.1       <none>        443/TCP             6h
nso-svc          ClusterIP   None            <none>        8080/TCP            14s
nso-svc-master   ClusterIP   10.108.126.92   <none>        2024/TCP,8080/TCP   14s
It will also simplify if we export the IP address to NSO master
test@kube-1:~$ export NSO_IP=$(kubectl get service nso-svc-master | tail -n +2 | awk '{print $3}')
test@kube-1:~$ echo $NSO_IP
10.102.2.60
Test deployment of NSO
In our first test, we will deploy NSO with one master and two slaves, distributed on the three nodes.
To select a master between themselves, we're launching a leader elector container as a sidecar to NSO. The leader-elector exposes a HTTP API, where each pod can query for the master. This is done by a HTTP GET on URL http://localhost:4040. The call returns the hostname of the master.
Please go to the k8s-lab/test-deployment directory and look at nso.yml
apiVersion: apps/v1
kind: StatefulSet
metadata:
spec:
  selector:
    matchLabels:
      app: nso-app
  serviceName: nso-svc
  # Deploy three instances of NSO
  replicas: 3
  template:
    metadata:
      labels:
        app: nso-app
    spec:
      # Specify anti-affinity to make sure NSO nodes are not
      # scheduled on the same k8s node
      affinity:
        podAntiAffinity:
          requiredDuringSchedulingIgnoredDuringExecution:
            - labelSelector:
                matchExpressions:
                  - key: app
                    operator: In
                    values:
                      - nso-app
              topologyKey: "kubernetes.io/hostname"
      containers:
        - name: nso-master
          image: kube-1:5000/nso-k8s-lab
          # Probes for liveness and readiness
          livenessProbe:
            httpGet:
              path: /restconf/data/ncs-state
              port: 8080
              httpHeaders:
                - name: Authorization
                  # echo -n "admin:admin" | base64
                  value: Basic YWRtaW46YWRtaW4=
          readinessProbe:
            httpGet:
              port: 8080
              httpHeaders:
          ports:
          - containerPort: 2024
          - containerPort: 8080
        # The leader elector side car. HTTP GET on http://localhost:4040
        # will return the leader
        - name: elector
          image: fredrikjanssonse/leader-elector:0.6
          args:
            - --election=nso-svc
            - --http=localhost:4040
          ports:
            - containerPort: 4040
              protocol: TCP
And to deploy the test
test@kube-1:~$ kubectl create -f nso.yml
statefulset.apps/nso created
NOTE: This might take a while since the NSO image have to be pulled from the registry to each of the k8s nodes.
To continuously check status you can watch the pods.
NOTE: the nodes on which each NSO pod is scheduled on may vary on your system.
test@kube-1:~$ watch kubectl get pod -o=wide
NAME      READY     STATUS    RESTARTS   AGE       IP           NODE      NOMINATED NODE
nso-0     2/2       Running   0          2m        10.244.2.2   kube-3    <none>
nso-1     2/2       Running   0          1m        10.244.1.2   kube-2    <none>
nso-2     2/2       Running   0          1m        10.244.0.4   kube-1    <none>
After a while you should see the pods deployed, one on each node.
To see which was elected as leader, you have a couple of options
test@kube-1:~$ kubectl describe endpoints nso-svc
Namespace:    default
Labels:       <none>
Annotations:  control-plane.alpha.kubernetes.io/leader={"holderIdentity":"nso-0","leaseDurationSeconds":10,"acquireTime":"2018-08-21T22:17:15Z","renewTime":"2018-08-21T22:19:44Z","leaderTransitions":0}
Subsets:
  Addresses:          10.244.0.4,10.244.1.2,10.244.2.2
  NotReadyAddresses:  <none>
  Ports:
    Name   Port  Protocol
    webui  8080  TCP
Events:  <none>
Or you can log into one of the pods
test@kube-1:~$ kubectl exec -it nso-0 bash
Defaulting container name to nso-master.
Use 'kubectl describe pod/nso-0 -n default' to see all of the containers in this pod.
root@nso-0:/# curl http://localhost:4040
{"name":"nso-0"}
root@nso-0:/# exit
We can also query the NSO HA status
root@nso-0:/# ncs_load -F o -o -p /ncs-state/ha
  "data": {
    "tailf-ncs-monitoring:ncs-state": {
      "ha": {
        "mode": "master",
        "node-id": "nso-0",
        "connected-slave": ["nso-1", "nso-2"]
root@nso-0:/# exit
So we can see that NSO have connected two slaves
Test HA
To test HA we can modify some data in NSO. For this there is a simple action in NSO, the action will simply increase a counter (in config) and store which host (i.e. the master) last made a change.
We can invoke the test action as follows
test@kube-1:~$ http_proxy="" curl -H "Content-Type: application/yang-data+json" -d "" -u admin:admin http://$NSO_IP:8080/restconf/data/ha-test/ping
And to check the result
test@kube-1:~$ http_proxy="" curl -u admin:admin http://$NSO_IP:8080/restconf/data/ha-test
<ha-test xmlns="http://example.com/ha-test"  xmlns:ha-test="http://example.com/ha-test">
  <count>2</count>
  <last-host>nso-0</last-host>
</ha-test>
So in my run above, I can see the nso-0 is the master.
Let's kill the nso-0 pod and force a leadership change.
Sometimes the restart of the master is so quick, that a new leader is not elected. If that happens, we can use a trick to force selection of a new leader. The pods are configured to not run on the same node (see nso.yml), so if we disable scheduling on one node, we can prevent one of the pods to come up.
First let's see where each pod is running
test@kube-1:~$ kubectl get pods -o=wide
nso-0                    2/2       Running   0          1m        10.244.2.10   kube-3   <none>
nso-1                    2/2       Running   0          59s       10.244.1.11   kube-2    <none>
nso-2                    2/2       Running   0          42s       10.244.0.4    kube-1    <none>
Here I see that nso-0, the leader, is running on kube-3. Let's disable scheduling on that node
NOTE: Make sure you select the correct node for your system.
test@kube-1:~$ kubectl cordon kube-3
node/kube-3 cordoned
And now if we delete nso-0, it will not come up until we uncordon the node
test@kube-1:~$ kubectl delete pod nso-0
pod "nso-0" deleted
Now we can redo the action test again
  <count>4</count>
  <last-host>nso-1</last-host>
</ha-test>
And voila, the new master is nso-1 and more importantly, the data is not lost.
Let's uncordon our node again to let nso-0 be scheduled.
test@kube-1:~$ kubectl uncordon kube-3
node/kube-3 uncordoned
test@kube-1:~/nfs/kube-ha/k8s-lab/test-deployment$ kubectl get pods
nso-0                    1/2       Running   0          1m
nso-1                    2/2       Running   0          14m
nso-2                    2/2       Running   0          14m
All good... but what will happen if we kill all pods?
test@kube-1:~$ kubectl get pods | grep nso | awk '{print $1}' | xargs kubectl delete pod
pod "nso-0" deleted
pod "nso-1" deleted
pod "nso-2" deleted
Wait for the pods to come back up
Now let's check the config again
Empty CDB, when all pods are gone and there is no persistent storage, all data is lost.
Let's delete the current deployment
$ kubectl delete -f nso.yml
statefulset.apps "nso" deleted
Shortly the pods should be removed
$ kubectl get pod
No resources found.
NSO with Persistent Storage
Install GlusterFS
We'll install GlusterFS as our replicated storage.
On the master node, we've already checked out a git repo that will help setting up GlusterFS.
First thing we need to do is load a couple of modules on the k8s nodes. Please go to k8s-lab/install-glusterfs.
There you'll run an ansible playbook that will load the relevant modules on all the hosts.
test@kube-1:~$ ansible-playbook -i hosts.yml glusterfs.yml
PLAY [Build Hosts] ***************************************************************************************************
TASK [Gathering Facts] ***********************************************************************************************
ok: [kube-2]
ok: [kube-3]
ok: [kube-1]
TASK [Modprobe] ******************************************************************************************************
ok: [kube-3] => (item=dm_mirror)
ok: [kube-1] => (item=dm_mirror)
ok: [kube-2] => (item=dm_mirror)
ok: [kube-2] => (item=dm_snapshot)
ok: [kube-3] => (item=dm_snapshot)
ok: [kube-1] => (item=dm_snapshot)
ok: [kube-2] => (item=dm_thin_pool)
ok: [kube-1] => (item=dm_thin_pool)
ok: [kube-3] => (item=dm_thin_pool)
PLAY RECAP ***********************************************************************************************************
kube-1                     : ok=2    changed=0    unreachable=0    failed=0
kube-2                     : ok=2    changed=0    unreachable=0    failed=0
kube-3                     : ok=2    changed=0    unreachable=0    failed=0
Please go to ~/gluster-k8s/deploy.
There you'll find a file called topology.json
  "clusters": [
      "nodes": [
          "node": {
            "hostnames": {
              "manage": [
                "kube-1"
              "storage": [
                "10.0.0.4"
            "zone": 1
          "devices": [
            "/dev/sdb"
          "node": {
            "hostnames": {
              "manage": [
                "kube-2"
              "storage": [
                "10.0.0.5"
            "zone": 1
          "devices": [
            "/dev/sdb",
          "node": {
            "hostnames": {
              "manage": [
                "kube-3"
              "storage": [
                "10.0.0.6"
            "zone": 1
          "devices": [
            "/dev/sdb",
It already have the correct names and IP address for your k8s nodes.
To install GlusterFS we simply run the gk-deply script, with -g to provision gluster pods as well.
$ ./gk-deploy -v -g
Deployment complete!
Now navigate back to k8s-lab/install-glusterfs, there you'll find a file called storage-class.yml.
NOTE: This file will need to bo modified to point to the heketi/glusterfs service
$ kubectl get service heketi
heketi                     ClusterIP   10.98.79.86     <none>        8080/TCP            15m
Edit storage-class.yml to match the IP address above
$ vim storage-class.yml
apiVersion: storage.k8s.io/v1
kind: StorageClass
metadata:
provisioner: kubernetes.io/glusterfs
parameters:
  resturl: "http://10.98.79.86:8080"
NOTE: If you're behind a proxy, you'll need to add the IP address above to the no_proxy for k8s. Please modify /etc/kubernetes/manifests/kube-controller-manager.yaml
    - name: no_proxy
      value: .cisco.com,localhost,127.0.0.1,10.0.0.0/8,kube-1,kube-2,192.168.0.0/16,10.98.79.86
Modifying this file will automatically reload k8s controller service.
Now let's create the storage class
$ kubectl create -f storage-class.yml
storageclass.storage.k8s.io/glusterfs-storage created
To test the storage, we will create a persistent volume claim, please see pvc.yml
kind: PersistentVolumeClaim
apiVersion: v1
metadata:
spec:
  accessModes:
    - ReadWriteOnce
  resources:
    requests:
      storage: 1Gi
  storageClassName: glusterfs-storage
$ kubectl create -f pvc.yml
persistentvolumeclaim/test created
$ kubectl get pvc
NAME      STATUS    VOLUME                                     CAPACITY   ACCESS MODES   STORAGECLASS        AGE
test      Bound     pvc-be2c9bcd-a61e-11e8-9703-0050568923a4   1Gi        RWO            glusterfs-storage   24s
We can also check the persistent volume created from this claim
$ kubectl get pv
NAME                                       CAPACITY   ACCESS MODES   RECLAIM POLICY   STATUS    CLAIM          STORAGECLASS        REASON    AGE
pvc-be2c9bcd-a61e-11e8-9703-0050568923a4   1Gi        RWO            Delete           Bound     default/test   glusterfs-storage             1m
When we know it works, we're can delete the volume claim
$ kubectl delete -f pvc.yml
persistentvolumeclaim "test" deleted
After about a minute, the claim and the volume should be gone
$ kubectl get pv,pvc
No resources found.
With that we have a persistent, distributed storage installed.
Let's move back to NSO to utilize this.
NSO on GlusterFS
The next step is to run our NSO containers on the persistent storage.
The directories that needs to be persisted in an NSO project are logs, ncs-cdb and the state directory.
Please navigate to k8s-lab/persistent-nso and check out nso.yml. It has been modified from the previous version
FIXME: Export NC port
FIXME: Use HA state for readiness and liveliness
apiVersion: apps/v1
kind: StatefulSet
metadata:
spec:
  selector:
    matchLabels:
      app: nso-app
  replicas: 3
  template:
    metadata:
      labels:
        app: nso-app
    spec:
      affinity:
        podAntiAffinity:
            - labelSelector:
                matchExpressions:
                  - key: app
                    operator: In
                    values:
                      - nso-app
      containers:
        - name: nso-master
          livenessProbe:
            httpGet:
              port: 8080
              httpHeaders:
          readinessProbe:
            httpGet:
              port: 8080
              httpHeaders:
          ports:
          volumeMounts:
            - name: logs
              mountPath: /app/nso_project/logs
            - name: state
              mountPath: /app/nso_project/state
            - name: cdb
              mountPath: /app/nso_project/ncs-cdb
        - name: elector
          args:
          ports:
              protocol: TCP
  volumeClaimTemplates:
  - metadata:
    spec:
      accessModes: [ "ReadWriteOnce" ]
      resources:
        requests:
          storage: 1Gi
  - metadata:
    spec:
      resources:
        requests:
          storage: 1Gi
  - metadata:
    spec:
      resources:
        requests:
          storage: 1Gi
FIXME: Certificates for NSO SSL, from Bruce
So for each of cdb, logs and state, we will create a persistent volume claim for 1Gb of storage.
Let's deploy this
This will take some time and you can check the status
$ watch kubectl get pods,pvc,pv
Every 2.0s: kubectl get pods,pvc,pv        kube-1: Wed Aug 22 10:15:32 2018
pod/glusterfs-4dgmv          1/1       Running   0          17m
pod/glusterfs-b45nm          1/1       Running   2          2h
pod/glusterfs-gvqfq          1/1       Running   1          2h
pod/heketi-86f98754c-cmt6s   1/1       Running   4          2h
pod/nso-0                    2/2       Running   0          1m
pod/nso-1                    2/2       Running   0          43s
pod/nso-2                    0/2       Pending   0          8s
persistentvolumeclaim/cdb-nso-0     Bound     pvc-cf316753-a62e-11e8-a520-0050568923a4   1Gi        RWO            glusterfs-storage   1m
persistentvolumeclaim/cdb-nso-1     Bound     pvc-e05c7112-a62e-11e8-a520-0050568923a4   1Gi        RWO            glusterfs-storage   43s
persistentvolumeclaim/cdb-nso-2     Pending        glusterfs-storage   8s
persistentvolumeclaim/logs-nso-0    Bound     pvc-cf31f0ac-a62e-11e8-a520-0050568923a4   1Gi        RWO            glusterfs-storage   1m
persistentvolumeclaim/logs-nso-1    Bound     pvc-e059086b-a62e-11e8-a520-0050568923a4   1Gi        RWO            glusterfs-storage   43s
persistentvolumeclaim/logs-nso-2    Pending        glusterfs-storage   8s
persistentvolumeclaim/state-nso-0   Bound     pvc-cf3289c0-a62e-11e8-a520-0050568923a4   1Gi        RWO            glusterfs-storage   1m
persistentvolumeclaim/state-nso-1   Bound     pvc-e05ba39d-a62e-11e8-a520-0050568923a4   1Gi        RWO            glusterfs-storage   43s
persistentvolumeclaim/state-nso-2   Pending        glusterfs-storage   8s
persistentvolume/pvc-cf316753-a62e-11e8-a520-0050568923a4   1Gi        RWO            Delete           Bound     default/cdb-nso-0     glusterfs-storage             55s
persistentvolume/pvc-cf31f0ac-a62e-11e8-a520-0050568923a4   1Gi        RWO            Delete           Bound     default/logs-nso-0    glusterfs-storage             59s
persistentvolume/pvc-cf3289c0-a62e-11e8-a520-0050568923a4   1Gi        RWO            Delete           Bound     default/state-nso-0   glusterfs-storage             55s
persistentvolume/pvc-e059086b-a62e-11e8-a520-0050568923a4   1Gi        RWO            Delete           Bound     default/logs-nso-1    glusterfs-storage             25s
persistentvolume/pvc-e05ba39d-a62e-11e8-a520-0050568923a4   1Gi        RWO            Delete           Bound     default/state-nso-1   glusterfs-storage             21s
persistentvolume/pvc-e05c7112-a62e-11e8-a520-0050568923a4   1Gi        RWO            Delete           Bound     default/cdb-nso-1     glusterfs-storage             29s
After a while you should see all pods get status running, at that point press ctrl-c to break the watch.
Let's create some configuration data in NSO
  <count>1</count>
</ha-test>
Now let's get the HA status
$ http_proxy="" curl -u admin:admin http://$NSO_IP:8080/restconf/data/ncs-state/ha
  <mode>master</mode>
  <node-id>nso-0</node-id>
  <connected-slave>nso-1</connected-slave>
  <connected-slave>nso-2</connected-slave>
</ha>
Test HA Failover
By running the command above, we can see that nso-0 is the master.
First test is simply to kill that pod and make sure everything comes up again.
NOTE Make sure you kill the pod that's the leader when you run.
pod "nso-0" deleted
After a short while, nso-0 will be back. Sometimes, depending on timing, nso-0 might still be the leader.
  <mode>master</mode>
</ha>
If nso-0 is still the leader, we can use the cordon/uncordon trick to force selection of a new leader.
glusterfs-4dgmv          1/1       Running   0          1h        10.0.0.4      kube-1    <none>
glusterfs-b45nm          1/1       Running   2          3h        10.0.0.6      kube-3    <none>
glusterfs-gvqfq          1/1       Running   1          3h        10.0.0.5      kube-2    <none>
heketi-86f98754c-cmt6s   1/1       Running   4          3h        10.244.1.7    kube-2    <none>
pod "nso-0" deleted
And now if we check the pods
test@kube-1:~/nfs/kube-ha/k8s-lab/persistent-nso$ kubectl get pods
nso-0                    0/2       Pending  0          23s
nso-1                    2/2       Running   0          3m
nso-2                    2/2       Running   0          3m
We'll also see a new leader elected
  <mode>master</mode>
  <node-id>nso-1</node-id>
</ha>
Last, we can uncordon the node to let nso-0 be scheduled.
$ kubectl get pods
nso-1                    2/2       Running   0          5m
nso-2                    2/2       Running   0          4m
  <mode>master</mode>
  <connected-slave>nso-0</connected-slave>
</ha>
Let's do the HA test again
  <count>3</count>
</ha-test>
All good!
Now if we redo the test where we kill all the NSO pods
pod "nso-0" deleted
pod "nso-1" deleted
pod "nso-2" deleted
Deleting and spinning up the pods may take a while, watch the status
When the NSO pods are up, let's check the config again
  <count>3</count>
</ha-test>
All came up with no data lost.
Clean up Persistent Volume Claims
By default, when the NSO stateful set is deleted, k8s will not delete the volume claims. To clean up we can do this (NOTE: this will remove all PVCs):
$ kubectl get pvc | tail -n +2 | awk '{print $1}'  | xargs kubectl delete pvc
persistentvolumeclaim "cdb-nso-0" deleted
persistentvolumeclaim "cdb-nso-1" deleted
persistentvolumeclaim "cdb-nso-2" deleted
persistentvolumeclaim "logs-nso-0" deleted
persistentvolumeclaim "logs-nso-1" deleted
persistentvolumeclaim "logs-nso-2" deleted
persistentvolumeclaim "state-nso-0" deleted
persistentvolumeclaim "state-nso-1" deleted
persistentvolumeclaim "state-nso-2" deleted
Beginner
Thanks for sharing the info regarding cluster building by using 3 nodes in Kubernetes (k8s). In the article the explanation part is very impressive and overall the entire procedure was vey informative.
Thanks for the article.
