This is the most common use case for NSO. Layer 3 and 2 VPNs are used to deliver Business VPN services, but also as transport infrastructure for other services, e.g. Mobile Backhaul, etc. Here is a solution overview describing this use case.
HiDevtools have an xpath eval option where xpath expressions can be tested. Really useful, but where those expressions actually work? In XML templates? They seem to not work in YANG as leafrefs or tailf:default-ref. This is my situation:admin@ncs(con...
view more
Hi.We have a resource-manager on server A with bunch of id-pools and allocations. We are looking how to clone that into server B. For example, ncs_load fails:ncs_load: 642: maapi_load_config(sock, tid, flags, abspath(argv[0])) failed: external error (19):...
view more
Hello,It's my first time installing nso on my mac m1 laptop. I did it via local install and ncs_cli -u admin works fine. I can do "?" and see many commands that I have access to. After searching for hours on how to solve this, it seemed like I need t...
view more
The NSO Config Monitor is targeted to discover and report unmanaged device configurationsas well as configuration changes that were introduced outside of NSO. It is designed to work as plug-in package named config-monitor, which can be installed and used&...
view more
Getting the below error while upgrading from lower version to higher version.
admin@ncs# configEntering configuration mode terminaladmin@ncs(config)# devices migrate old-ned-id cisco-staros-cli-5.37 new-ned-id cisco-staros-cli-5.40migrate-result {d...
view more
