Hi All,
I'm applying a template using _ncs.maapi APIs, is there any way to rollback the applied template ?
with maapi.single_write_trans("admin", "system", db=ncs.RUNNING) as th:
comp_vars = dict(comp_vars)
vars = ncs.template.Variables()
vars.a...
view more
A great question! Before I finalize the NSO Developer Days agenda and share the details, I'd like to make a final call to get your input!
Like most things in life, Network Automation is not a trivial thing. Since you are here you have probably decided tha...
view more
Hi all, I am encountering a issue during compiliation of Juniper-Junos-NED in Docker container.junos.fxs is linked in load-dir directory, but junos.fxs is missed after make clean allBut junos-rpc.fxs is compiled and exists in load-dir directory.Other...
view more
Hi there, I'm trying to setup a cml cicd pipeline using this example from Joe Clark: https://github.com/CiscoDevNet/cml-cicdI have noticed that he created a vlan-service and a switch-topology service in NSO 5.4 so I have recompiled the service t...
view more
Hi all,I'm running NSO services on Nokia 7360 devices and alu-isam NED (ncs-4.7.8-alu-isam-1.2).I need to investigate when NED software could put a template command in "shutdown".Taking a look into NED implementation I've found shutdown management in java...
view more
