I'm running CBD2.7.1 and installed a public wildcard certificate.The following error is flashing on the top of the dashboard:"Server certificate does not contain your server address in Subject Alternative Name."Is this a bug when using wildcard certs...
Hi,I have tried to retrieve serial number info for 3 units of the Cisco WAP4410N Access Point devices via Web GUI and CLI, but it seems can't find the serial number info for this model. Kindly advise further, thanks.Regards,Wilson Leong
Hi all,The license of Cisco Switch has lapsed. Would it still eligible to obtain software updates and subsequent patching? As my current Cisco Switch did not renew the license while looking the trend of new vulnerabilities arising from time to time. ...
Scenario,Host-A(10.10.30.3/24) connects to access port on SwitchA with various other vlans also configured via access ports. SwitchA connects on a Trunk port to a CatSwitch. Firepower inside ½ interface trunks to CatSwitch. On The CatSwitch 3 vlans; ...
hello, we have a cisco spa504g at my work place connected through Telstra. it has been saying 'initializing network' for 2 days now and the microphone button is red. we have tried resetting/restarting in each and every way but no changes. also the ph...
I have recently bought a SPA 112, and arrived yesterday, I was able to get into config settings, i factory reset it, its the same ip but when i look it up its not working. I need help with this, and I Think it might be company locked. I really need h...
We have a Cisco Switch 350 that just powers down on its own. The logs do not show anything as it is a limited log and cleared when it powers off. It happens often and it's not a power outage or power brownout. The switch is also on a good UPS and we ...
I have a Linksys SPA2100 ATA that I used with a previous VoIP provider. I did a factory reset but their profile rule is still listed in the first Profile Rule section under the Provisioning tab. Profile Rule B, C and D are blank and I can enter a pro...
The SPA2102 is running firmware 5.2.5. Line 2 works fine. If I set up line 2 incorrectly, I get "failed" as expected. Line 1 is another story. No matter how I set up line 1, the status remains "Not Registered". It would seem that the line is not enab...
Hi,when i connected cisco navigator panel to codec kit plus it shows 'has not yet received DNS address from DHCP' and i tried to connect with wifi but the wifi doesnot work because i disconnected the ethernet from codec and check with navigator panel...
Is there a way to access your messages from outside the office? I have tried *, # and looked at our options but do not see anything refering to outside access.
Hey there, We use some SG500s here and I can't get them to work with our VLANs. We have some ports on our switch that are tagged with VLANs, but whenever I untag them using the GUI, I can see the changes being made when I telnet into the switch. I th...
Hello, The Cisco Business Dashboard API Swagger file is missing. The link on the API reference page for Swagger file is broken/missing (Return code 404) Source: https://developer.cisco.com/docs/business-dashboard/#!api-reference Resources Support ...
hi, I have to acquire the signal from SFP with fiber port and redirect the signal to ports number 47 and 48.the problem is that only with the transmission cable connected to the SFP, the port does not light up and the signal is not processed.How can...
So the Cisco Small Business RV340, RV345, RV 160, RV260, RV345P, RV340W, RV260W, RV260P and RV160W VPN Router has all reached EOS & EOL. That's every small business router that Cisco currently has. Per Cisco, there is currently no product migration...
