06-02-2014 06:53 AM
Hi!
I am developing integration of webex conferences with my site. But since Thursday I experience this problem when create meeting with XML API : Corresponding MeetingType not found. I am using apidemoeu.webex.com. I do not provide MeetingType in XML Schema when create meeting. Previously it worked fine.
Hope, you can help me with that.
08-04-2014 09:03 PM
I am also facing the similar kind of problem. I want to create user by giving only one session type in the XML API but it enabling all the session types.
here is the XML API I am using.
string xml = "<?xml version=\"1.0\" encoding=\"ISO-8859-1\"?>";
xml += "<serv:message xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xmlns:serv=\"http://www.webex.com/schemas/2002/06/service\">";
xml += "<header>";
xml += "<securityContext>";
xml += "<webExID>" + webExId + "</webExID>";
xml += "<password>" + password + "</password>";
xml += "<siteID>" + siteId + "</siteID>";
xml += "<partnerID>" + partnerId + "</partnerID>";
xml += "</securityContext>";
xml += "</header>";
xml += "<body>";
xml += "<bodyContent ";
xml += "xsi:type=\"java:com.webex.service.binding.user.CreateUser\">";
xml += "<firstName>" + FirstName + "</firstName>";
xml += "<lastName>" + LastName + "</lastName>";
xml += "<webExId>" + userName + "</webExId>";
xml += "<email>" + emailId + "</email>";
xml += "<password>" + userPassword + "</password>";
xml += "<privilege>";
xml += "<host>true</host>";
xml += "</privilege>";
xml += "<active>ACTIVATED</active>";
xml += "<personalMeetingRoom>";
xml += "<welcomeMessage>This is welcome message</welcomeMessage>";
xml += "<headerImageBranding>false</headerImageBranding>";
xml += "</personalMeetingRoom>";
xml += "<sessionOptions>";
xml += "<defaultSessionType>128</defaultSessionType>";
xml += "<defaultServiceType>SalesCenter</defaultServiceType>";
xml += "<autoDeleteAfterMeetingEnd>false</autoDeleteAfterMeetingEnd>";
xml += "<displayQuickStartHost>true</displayQuickStartHost>";
xml += "<displayQuickStartAttendees>false</displayQuickStartAttendees>";
xml += "</sessionOptions>";
xml += "<supportCenter>";
xml += "<orderTabs>";
xml += "<tab>Tools</tab>";
xml += "<tab>Desktop</tab>";
xml += "<tab>Application</tab>";
xml += "<tab>Session</tab>";
xml += "</orderTabs>";
xml += "</supportCenter>";
xml += "</bodyContent>";
xml += "</body>";
xml += "</serv:message>";
Please tell me that how can I enable the session type that I want to make enable.
