12-04-2021 02:31 PM - modifié 12-04-2021 02:35 PM
Hi I got an annoying problem, I've uninstalled PT 8.1.0 many times and even did a clean install. But every time I am opening the router in packet tracer and get into CLI. The voice over just keeps on going, disabling it did not work... Is this a bug?
Other solution I've tried:
- Updating from Catalina to Big Sur after installing PT it gave the same problem...
le 01-18-2024 09:46 PM
Thank you so much for your kind support. You saved me.
le 10-19-2022 02:34 PM
Go to preferences - Interface - Disable CLI text to speech.
le 05-18-2024 11:23 PM
I owe you my life thanks!!!
le 02-14-2022 12:17 PM
Gents,
i've just updated my PT to 8.1.1 and unfortunatelly the same bug exists - the CLI text is spoken out and there is no way to turn it off
Does anyone have an idea how this can be fixed?
le 10-18-2022 04:06 PM
Hi everyone
For Mac users and problem solution
First, open the packet tracer with full screen and then click on the cisco packet tracer on the top left and then the preferences option, and a window will be opened with lots of options...tick the option " Disable CLI text to speech " ...your problem will be solved ...Have a good time
le 02-23-2022 11:18 AM
Hi, same problem here, running PT 8.1.1 in a Mac Mini M1 with Mojave.
I have tried every posible solution, but I still have the voice ringing in my terminal and in my head...
le 02-24-2022 11:13 AM
I'm using Cisco Packet Tracer v 8.1.1.0022 and have the same problem - sounds like MacBook is using the VoiceOver feature to read all of the CLI text when you enter a command. I don't know if Cisco has fixed it by adding the following setting, which I found to be de-selected by default. Do the following to fix this problem:
On the 'top menu' select
Cisco Packet Tracer > Preferences
(Navigate to the 'Interface' tab if it's not already open)
Check the box labeled 'Disable CLI Text to Speech'
Close the dialog box - Problem Solved!
02-24-2022 12:04 PM - modifié 02-24-2022 12:07 PM
that seems to be the solution, thanks for the advise
Petko,
PS: Attached is a screenshot of the solution
le 04-03-2022 05:25 AM
le 07-21-2022 03:56 PM
Hey there, hezhez:
Had the same issue running PT 8.1.1.0022 in Big Sur as well. Very annoying indeed, however, the solution (as it is most of the time) is quite simple:
Go to Preferences > Customize User Experience > Check the "Disable CLI Text to Speech". You should be good after that.
le 10-10-2022 07:13 PM
Experiencing this issue as well. Surprised its been so long and they still haven't fixed or addressed it.
le 10-19-2022 02:33 PM
le 10-19-2022 02:38 PM
Hi everyone
le 11-21-2022 06:41 PM
12-10-2022 11:02 PM - modifié 12-10-2022 11:03 PM
Yeap - most recent responses are the solution. It would be nice to see the option to be disabled by default, with a prompt upon first boot to enable the setting (for anyone needing access to accessibility options from the get go).
Solution:
*) Upgrade to Version 8.2.0 via a fresh install, if possible.
1) Navigate to Cisco Packet Tracer > Preferences
2) In the top half of the Interfaces tab along the left column, enable Disable CLI Text to Speech.
Découvrez et enregistrez vos notes préférées. Revenez pour trouver les réponses d'experts, des guides étape par étape, des sujets récents et bien plus encore.
Êtes-vous nouveau ici? Commencez par ces conseils. Comment utiliser la communauté Guide pour les nouveaux membres
