12-04-2021 02:31 PM - modifié 12-04-2021 02:35 PM
Hi I got an annoying problem, I've uninstalled PT 8.1.0 many times and even did a clean install. But every time I am opening the router in packet tracer and get into CLI. The voice over just keeps on going, disabling it did not work... Is this a bug?
Other solution I've tried:
- Updating from Catalina to Big Sur after installing PT it gave the same problem...
le 02-02-2023 08:41 AM
le 02-08-2023 05:00 PM
Hi!
Top Menu -> Cisco Packet Tracer -> Preferences -> Disable CLI Texto to Speech
Shorter way: cmd + , -> Disable CLI Texto to Speech
You're welcome!
04-25-2023 09:16 AM - modifié 04-25-2023 09:17 AM
I was wrapping my head around the mac settings, and saw it was disabled.
It is not a Packet Tracer Bug, its a setting that should be off by default but it's not,
So I went into Packet Tracer directly .....
Go to Preferences> Interface Tab> Make sure the check mark is on >Disable CLI Text to Speech
le 06-11-2023 10:25 PM
This is as simple as that. Thanks
11-03-2023 12:19 PM - modifié 11-03-2023 12:20 PM
Thank you for the solution
le 03-04-2024 12:20 AM
https://github.com/kyleneideck/BackgroundMusic?tab=readme-ov-file
try this
its work!!
Découvrez et enregistrez vos notes préférées. Revenez pour trouver les réponses d'experts, des guides étape par étape, des sujets récents et bien plus encore.
Êtes-vous nouveau ici? Commencez par ces conseils. Comment utiliser la communauté Guide pour les nouveaux membres
