10-14-2020 08:06 AM
I am supposed to design a network for an organization having multiple buildings and/or multiple campuses at different parts of the world.
I need to demonstrate/justify all concepts like type of link and type of network devices used, VLAN, inter-VLAN routing, subnetting, static routing, dynamic routing, Wireless LAN, HTTP server, DHCP server.
Now the thing is I am a beginner and the things which are taught in our class are pretty basic and we are supposedto build a design like this, so if anyone has somewhat reference or something they have build will be really helpful to me.
I checked the cisco validated designs and they are way above my knowledge and if I try to implement that then the professor is definitely gonna consider a copy-work.
So please help this beginner. Thank you
10-14-2020 08:28 AM
You do not required to copy totally information, but worth reading all CVD and digest and make your own diagram and document and post here, i am sure we can look and suggest, at this stage we are not sure what knowledge you have what we can suggest here, as you mentioned you are starter ? this is more of technical community, but we happy to help once you have something in place.
https://www.cisco.com/c/en/us/solutions/design-zone/cisco-validated-profiles.html
10-14-2020 08:38 AM
