03-08-2014 07:54 PM
I followed all the directions/instructions to set up OpenDNS, however its not working. I tried all the test pages and all I get is the OOPS... page. I have a netgear router connected to an actiontec DSL modem. Just because, I tried using those settings on the modem and that diddnt work either. As of now I have put everything back to the settings they were before and only have the openDNS setting on the router.
Thanks for the help.
03-08-2014 07:56 PM
btw, I flushed everything too. Still not working. Ive tried everything on both, firefox and IE.
03-09-2014 05:14 AM
Post the complete plain text output of the following command here:
nslookup -type=txt which.opendns.com. 208.67.220.220
03-09-2014 08:23 AM
thanks for the response
here are the results;
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Owner>nslookup -type=txt which.opendns.com. 208.67.220.220
Server: resolver2.opendns.com
Address: 208.67.220.220
Non-authoritative answer:
which.opendns.com text =
"1.lax"
C:\Users\Owner>
C:\Users\Owner>
03-09-2014 09:40 AM
That's fine, your ISP does not redirect your DNS queries, and you would be using the OpenDNS LA location.
If http://welcome.opendns.com/ still returns "Oops!", then you haven't correctly configured the OpenDNS resolver addresses. Maybe post screen shots of where they are configured. Try with configuring on the modem and on the router.
If you have a router with more than two DNS server entries, fill them with 208.67.220.222 and 208.67.222.220.
03-09-2014 02:07 PM
I configured both the router and the modem, flushed both resolver and browser.. still not working.
03-09-2014 02:12 PM
In case you have a Windows computer, post the plain text output of "ipconfig /all".
03-09-2014 02:17 PM
You may also try configuring just your computer (https://store.opendns.com/setup/computer/), then try the test again.
Be sure to either reboot your machine or clear both browser and the machine's DNS cache.
03-09-2014 02:55 PM
I configured my pc, flushed dns and browser, and it still is not working. As of now i have all three configured, modem, router, and pc.
heres my ipconfig/all;
C:\Users\Owner>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : H-Two
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Broadcast
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) Centrino(R) WiMAX 6250
Physical Address. . . . . . . . . : 64-D4-DA-19-8C-4C
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Wireless Network Connection 3:
Description . . . . . . . . . . . : Microsoft Virtual WiFi Miniport Adapter #
Physical Address. . . . . . . . . : 00-23-15-98-EF-35
Wireless LAN adapter Wireless Network Connection 2:
Wireless LAN adapter Wireless Network Connection:
Description . . . . . . . . . . . : Intel(R) Centrino(R) Advanced-N 6250 AGN
Physical Address. . . . . . . . . : 00-23-15-98-EF-34
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Atheros AR8131 PCI-E Gigabit Ethernet Con
troller (NDIS 6.20)
Physical Address. . . . . . . . . : BC-AE-C5-0F-B4-FC
Link-local IPv6 Address . . . . . : fe80::9b5:29de:9b9:4172%10(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.2(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Sunday, March 09, 2014 9:50:23 AM
Lease Expires . . . . . . . . . . : Monday, March 10, 2014 2:47:30 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 247246533
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-14-89-C1-F6-BC-AE-C5-0F-B4-FC
DNS Servers . . . . . . . . . . . : 208.67.222.222
208.67.220.220
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.{C50E073D-4236-46EB-8CCD-4EB7ED8B2202}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
C:\Users\Owner>
03-09-2014 03:28 PM
This looks fine, but I need to see another command output:
nslookup -type=txt debug.opendns.com.
03-09-2014 03:56 PM
C:\Users\Owner>nslookup -type=txt debug.opendns.com
Server: resolver1.opendns.com
Address: 208.67.222.222
debug.opendns.com text =
"server 14.lax"
"flags 20 0 2f4 4000800000000000000"
"id 0"
"source 71.209.224.205:52200"
C:\Users\Owner>
03-09-2014 04:32 PM
This DNS query went to OpenDNS, so your OS is using OpenDNS. You're still using the OpenDNS LA location, but your IP address 71.209.224.205 is not registered with your OpenDNS network yet ("id 0"). Go and get this corrected: https://dashboard.opendns.com/settings/
So, if http://welcome.opendns.com/ still returns "Oops!", then it's your browser circumventing OpenDNS and your OS. Flush the browser caches again, and check FireFox and IE if you have a proxy configured in the browsers, or if you use add-ons which may circumvent the DNS configured on your OS.
03-09-2014 04:42 PM
I updated that yesterday. but today when I checked it was different I had to update it. after updating...... IT WORKS! I have been "welcomed" to OpenDNS for the first time!
Thank You very much for all the support.
03-09-2014 04:52 PM
"I updated that yesterday. but today when I checked it was different I had to update it."
It seems you don't run an Updater. You must if you have a dynamic IP address.
https://support.opendns.com/entries/23282614-Where-do-I-download-an-OpenDNS-Dynamic-IP-updater-client-
