I need the details in this topic. Who has better technology. I checked out by the search engines and case studies, usually everyone goes to Nortel rather than cisco in DWDM technology, It means DWMDM technology is not mature in CISCO. AK
HiMy conception is :1. ONS 15305 (release 3.0, CTC-enabled) is a center of star network topology.2. two ONS 15305 (release 1.1.1 !!!) are end points of beams.3. PC for network monitoring is connected to central ONS 15305 (CTC-enabled).Q. Can I do net...
With the newer releases is it possible to do a 4 fiber BLSR (or) 2 seperate oc48 2 fiber blsr's in the same shelf?With the 10G 15454 can you do multiple oc48 2 fiber BLSRs in the trib slots?
Hi all,I have a strange problem with the optical gigabit interface of a Ciscoswitch 7609. This is the problem:I have two 7609 cisco switch (A and B) cross connect with a opticalfiber.All port of both switches are configured as followed:switchportswit...
Hello,We bought CTM 4.7 a while back; didn't use it since we had no system admin. I am new to CTM and so would like to know the default passwords for the default users like SysAdmin, SuperUser etc.Thanks
Hi!We have SDH network build on Huawei equipment(STM-1). But now we want to migrate to Cisco ONS. And we need to know strongly is Huawei SDH is compatible with Cisco?A know this is trivial, standarts is equal to all, but maybe someone have expirience...
I have a 3640 router installed with NM-1A-OC3MM. I upgraded the IOS and the new one is (C3640-I-M), Version 12.3(19), RELEASE SOFTWARE (fc2).ATM interface is showing in IOS. Do I need a right IOS. If yes than which one.Regards
Hi All,My Compnay will soon get 2 STM-1 Connections as a Direct Link between our NOC and 2 DataCenters. Transport between NOC and Datacenters is done by Telco Provider. Datacenters are just about .8km Cabeling but right now its not planned to interc...
HiCould you please provide me common information about some key steps, which i will have to do to upgrade ONS 15305 (R 1.1.1) up to R 3.0 ?Is this pocedure money free?ThanksRgds
Hi,There are two 15454E-E1-42 cards raised EQPT: Equipment Failure Alarms, and no other alarms related to any ports could be found, and it seemed no service have been affected.The problem is I could not find any way to clear EQPT:Equipment Failer ala...
HelloCould anybody provide me information about possibility of upgrade of ONS 15305 from realese 1.1.1 to release 3.0 ?Are there any addition requirements concerning hardware (memory and so on...)?Thanks in advance
I have two 15540,link with p-to-p topology,it now have problem,following is the log,could anybody know how to solve the problem.18:13:33: %LCMDC-3-MIB_FH_ELOSY_ALM: Egress FC/ESCON Loss of Sync ASSERT MAJOR Wave3/018:13:33: %LCMDC-3-FH_ELOSY_ALM: Eg...
HiCan some one tell me which ONS product i should use to interface with an SDH network (STM 4) and can interface with a Fiber channel switch.RegardsChampika
