Hi, In IPoDWDM project we don't have transponders in the NCS for the channels, so the lights initiated from the router then boosted by Amps in the NCS. My question if the OSC channel down, can i make DCN extension from NCS and how?
Hi, Can I perform system initialization, provisioning, alarm reporting, maintenance and diagnostics for the NCS2006 without placing TSCE in the shelf from Craft port on the ECU? thanks,
Dears, can we configure one port UDC to both SFP in the same TNCE. so we can transmitt the UDC traffic to both side west and east. the objective is, I have a DWDM ring . there is ASR903 router in each access site and i want to make out band managemen...
The Bug report for this issue states that it has been fixed in 10.521, however, the release notes indicate that it was resolved in 10.5.2.4. Excerpt from Release Notes: "The following critical issues have been resolved in Release 10.5.2.4: - Traffic...
Hello all. This may sound strange, but I am having difficulty getting a batch of G5486's working in our Chassie switch. Here's the details:The switch I'm trying to put them in is a C4507R with current software on it. It's being put in the WS-X4418...
Hi All, I have a question. i was given a task to poll the RSL, transmitting and receiving power level of all fibers connected to a Cisco 3600x switch on the network monitoring system eg PRTG. To check the above parameters on the switch, i do use t...
Hi everyone! I need some advice. I am planning to connect the following switches by multi-mode optical fiber: IE-3010-16S-8PC (with GLC-FE-100FX= into the 16 x SFP 100Mbps ports) and WS-C2960CX-8PC-L (GLC-SX-MMD into de 1Gbps uplinks). The port ...
Is there a specific list that shows a list of compatible 1GB SFP modules for use in the C3850-NM-2-10G? We have a GLC-SX-MMD and it is not working.
Hi Guys Does the mini GBIC port on the SG100 series SG200 series and SG300 series support GLC-SX-MMD or GLC-LH-SMD or please point on on a datasheet or compatibility matrix which shows this Regards, lucky
Hello,Two pc/router is connected to udc ports (both left side on 15454 M6 and pcs/routers have ip addr in same subnet). The 10g link is up between nodes. I'm using straight cables. But pcs cannot ping each other.What i need to do else to resolve the ...
Hi team, Can you please let me know if we can activate an alert to send an email each time a VC endpoint becomes unregistered on the system? waiting to hear from you.
I have a 3850 48T-E cisco switch and I want connect it to a Cisco 4500x switch. To make this connection I have rented a dark-fiber but the provider has installed a single SC port and I have a SFP 10GLR attached to my 3850 48T-E SwitchWhat type of pa...
Hello, I have a M6 chassis that running on 10.3.0 software without any issue. Recently, I upgraded it to 10.5.2 and the node wouldn't initialized. I could logged in the chassis and ping the node IP without any request timeout. I can see the node ...
Hello all, I ran into this same issue the last time I set up the CPO server and can't find the documentation I used to fix it. I am attaching the associated Log file and also the text of the actual error I am getting when I try and login. File 1 is...
Subject | Author | Posted |
03-27-2024 12:16 AM | ||
03-27-2024 12:09 AM | ||
09-10-2023 08:07 AM | ||
08-03-2023 03:20 AM | ||
06-14-2023 06:52 AM |
