Hello All,
Does someone know if FC 8G cwdm SFP (DS-CWDM8Gxxx) are supported with Cisco passive cwdm Mux line (CWDM-MUX8A, CWDM-OADM4) ?
All the doc that i've found for those Mux refers to 1/2 Gbps cwdm SFP but not 8/10 Gbps cwdm SFP.
Thanks in ad...
Hi.I have an implementation coming up of dark fibre which requires me to run ZX SFP's (cable distance more than 10 k's), but I need to put an attenuator into the receiving side of the SFP at each end.How do I figure out which one is the receiver?With...
I'm planning a large network deployment and I need a 10Gb-Fibre switch to connect the distribution switches in a Metropolitan Area Network to the Datacenter. I need a high speed backbone from each building to the Datacenter through this Core switch b...
Let me start by saying that I am primarily route/switch. My familiarity and knowledge of the ONS is very minimal. The enterprise I work for has a very large network where they have a mix of leased dark fiber where an SP provides the DWDM and a larg...
I have the 2960X Catalyst switches using the GLC-LH-SMD SFP Module. The facility existing cabling plant is OM3. Do I need to use the Mode conditioning fiber patch cables and if so where can I get such specifications based on existing infrastructure?...
Hello,I'm getting fiber installed at the house for my home office. The company is providing a:Juniper ACX2100It is completely locked down. So it will just provide one IP address. Here is the info they provide:
a fiber optic cable connection between y...
Hello Friends,
Some body today asked me, what is two pair fiber cable and does the switch 3750 (ws-c3750-24ts-s) support them.
can somebody, please let us know on this.
BR
Mohammad Thanveer
I have two of the 6200 fabric interconnects, and I need to connect to a port of the HP 5900 QSPF+ ports, I was thinking of getting one of these cables that QSFP that splits into 4 x 10GB cables.
The HP switch is a full 10GB ethernet switch w...
I'm using a GLC-SX-MMD transceiver and some fiber cable to connect my remote switch to my core switch. Looking at cisco documentation, it said that the operating distance is 275 ft because the fiber cable is MMF 62.5 um. But, when I use the OTDR fibe...
Good day,
I have Cisco 2911 (EHWIC-1GE-SFP-CU , GLC-SX-MMD, LC to SC Adapter. I want to configure PPPOE on cisco SFP port as diagram bellow:
Cisco R2911 (SFP Port) ---- (SC - LC Adapter) --- ISP
interface Dialer1
ip address negotiated
ip mtu 145...
I'm wrestling with adding 40-SMR1-C cards to NCS2006 shelves. When provisioning the card using XML from CTP I'm getting the error "Setting Refused..." in the logs. I've tried adding the card manually in CTC but the 40-SMR1-C is NOT showing anywhere...
I am setting up a new site and our requirement is to have DS3 connectivity. The issue is that we have a cisco 7206VXR router and the connection has been provisioned by the provider as DS3 channelized over STM1 (Optical connection SDH).
Plea...
I'm having trouble logging in my 15454 M6. The attachment is the error message that I kept getting. What should i do to fix this problem? Thank you in advance.
