Bit Error Rate BER B3 logs filling up
kaustav.gupta
I have a router connected to a provider via POS and once we commissioned the link we are receiving the following logs
010091: .May  7 06:58:34.353 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface POSx/x/x, changed state to down
010092: .May  7 06:59:04.320 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface POSx/x/x, changed state to up
010093: .May  7 06:59:12.317 UTC: %ASR1000_RP_SONET_ALARM-6-SONET: ASSERT CRITICAL POSx/x/x Threshold Cross Alarm - B3
010094: .May  7 06:59:12.317 UTC: %SONET-4-ALARM: SIP0/1:  POS0/1/0: B3 BER exceeds threshold, TC alert declared
The actual interface is configured as below.
interface POSXXX
no ip address
no ip redirects
no ip unreachables
encapsulation frame-relay IETF
load-interval 30
crc 32
pos framing sdh
pos scramble-atm
frame-relay lmi-type ansi
Question :   what can be the following causes ? Is it the router POS interface which is creating in payload corruption ?
Leo Laohoo
You've got a layer 1 issue.  Please post the output to the command "sh interface POS <BLAH>".
kaustav.gupta
sh int pos 0/1/0
POS0/1/0 is up, line protocol is up
  Hardware is SPA-1XOC12-POS
  MTU 4470 bytes, BW 622000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 1/255, rxload 4/255
  Encapsulation FRAME-RELAY IETF, crc 32, loopback not set
  Keepalive set (10 sec)
  Scramble enabled
  LMI enq sent  91286, LMI stat recvd 91273, LMI upd recvd 0, DTE LMI up
  LMI enq recvd 0, LMI stat sent  0, LMI upd sent  0
  LMI DLCI 0  LMI type is ANSI Annex D  frame relay DTE  segmentation inactive
  FR SVC disabled, LAPF state down
  Broadcast queue 0/256, broadcasts sent/dropped 0/0, interface broadcasts 0
  Last input 00:00:01, output 00:00:01, output hang never
  Last clearing of "show interface" counters 1w3d
  Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 371
  Queueing strategy: Class-based queueing
  Output queue: 0/40 (size/max)
  30 second input rate 9930000 bits/sec, 2470 packets/sec
  30 second output rate 1752000 bits/sec, 2236 packets/sec
     2041953470 packets input, 819671035376 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     968195 runts, 23 giants, 0 throttles
              0 parity
     1008516 input errors, 38377 CRC, 0 frame, 0 overrun, 0 ignored, 1921 abort
     1893429862 packets output, 205010313695 bytes, 0 underruns
     0 output errors, 0 applique, 0 interface resets
     0 unknown protocol drops
     0 carrier transitions
It's confirmed that your line is dirty.  Get the telco to run an end-to-end Bit Error Rate (BER) test.
