Highlighted
Beginner
C3048TP-1GE-sup fiber module
I am trying to use a GLC-LH-SM module in a c3048TP-1ge-sup switch. I cannot get the interface to come up. I can see in the logs that it sees when it is inserted and removed. The other side is also a GLC-LH-SM. I am able to get a link when connecting the fiber to other Cisco switches that are not 3048s, using the same module. The following says it is compatible:
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html
I have tried seeting the speed to 1000 and negotiate to auto. Still does not come up. Any idea why it won't come up?
1 REPLY 1
Highlighted
Hall of Fame Guru
Is your 3048 recognizing the transceiver type?
Can you provide "sh int" and "sh run int __" for the interface in question with the transceiver n place?
Content for Community-Ad
