ā12-19-2011 08:41 AM
Can you tell me is there any separate card for giving Channelized DS3. If possible pls provide tha part code number.
ā12-19-2011 09:07 AM
What device do you need a channelized card for ?
ā12-19-2011 09:44 AM
One of our branch location has to be connected with the Telco's Voice Switch. Our PBX is an analog PBX, Its for a Voice Requrement.thats why want to know is a channelized DS3 card required at the Telco end as well at my end.
Hope this clarifies...
ā12-19-2011 09:49 AM
You might get a better answer over on the voice forums.
A lot would depend on the model of PBX you have. If I recall correctly, the modules for PBS'x tend to be manufacturer dependent.
The Telco you are going to connect to should be providing you with some of this information..
