2248
Highlighted
Beginner
cisco 3450 stack images
I was wondering. I have 2 3750 stacked. One of it had an issue with the fan and had to take it out. I ordered a new one but it came with a different image as the one that is working right now.
The new one has c3750-ipbase9-mz and the old htat is Online now has ipservices
Will it work if I stack them with different image?
Everyone's tags (3)
4 REPLIES 4
Rising star
Re: cisco 3450 stack images
No, you will have a version mismatch... Update for the same IOS version before stacking.
Jaderson Pessoa
*** Rate All Helpful Responses ***
VIP Mentor
You can stack with different images once the major and minor numbers match
Read page 12 of the guide below for what to look for , but running same image as previously stated will make things smoother
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/stack_manager/configuration_guide/b_stck_152ex_2960-x_cg/b_stck_152ex_2960-x_cg_chapter_010.pdf
Rising star
Jaderson Pessoa
VIP Mentor
Having exact image will just ensure it stacks fully with all features you can still stack different models and versions once the major minor numbers match , the issue is some features available on image may not be available on both , which is why its recommend to use the same image but may not always be possible when stacking different platforms ,
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/stack_manager/configuration_guide/b_stck_152ex_2960-x_cg/b_stck_152ex_2960-x_cg_chapter_010.html
Content for Community-Ad
July's Community Spotlight Awards
