cisco 3450 stack images
Fotiosmark
I was wondering. I have 2 3750 stacked. One of it had an issue with the fan and had to take it out. I ordered a new one but it came with a different image as the one that is working right now.
The new one has c3750-ipbase9-mz and the old htat is Online now has ipservices
Will it work if I stack them with different image?
Jaderson Pessoa
No, you will have a version mismatch... Update for the same IOS version before stacking.
Jaderson Pessoa
*** Rate All Helpful Responses ***
You can stack with different images once the major and minor numbers match
Read page 12 of the guide below for what to look for , but running same image as previously stated will make things smoother
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/stack_manager/configuration_guide/b_stck_152ex_2960-x_cg/b_stck_152ex_2960-x_cg_chapter_010.pdf
Jaderson Pessoa
Having exact image will just ensure it stacks fully with all features you can still stack different models and versions once the major minor numbers match , the issue is some features available on image may not be available on both , which is why its recommend to use the same image but may not always be possible when stacking different platforms ,
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/stack_manager/configuration_guide/b_stck_152ex_2960-x_cg/b_stck_152ex_2960-x_cg_chapter_010.html
