03-29-2015 07:05 AM
Dear Team,
I have Cisco 4503 and I have inserted 1000BaseLH and light is not coming up but for 1000BaseSX its fine.
Please suggest.
CORE#show int GigabitEthernet1/18
GigabitEthernet1/18 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet Port, address is 001e.4aa6.b891 (bia 001e.4aa6.b891)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, Auto-speed, link type is auto, media type is 1000BaseLH
input flow-control is off, output flow-control is off
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicast)
0 packets output, 0 bytes, 0 underruns
0 lost carrier, 0 no carrier
CORE#show inventory
NAME: "GigabitEthernet1/18", DESCR: "1000BaseLH"
PID: TRF5735AALB202 , VID: A1 , SN: OPA11241478
Thank You,
Abhisar.
03-29-2015 01:18 PM
They require different fiber types. SX is designed for multimode while LH requires singlemode.
You also need compatible transceivers at the distant end.
03-30-2015 12:49 AM
Thanks Marvin,
It is solved.
https://supportforums.cisco.com/discussion/12464296/cisco-4503-1000baselh-sfp-light-not-coming-urgent
Thank You,
Abhisar.
03-29-2015 08:08 PM
