Highlighted
Beginner
Cisco 4503 "1000BaseLH" SFP light is not coming
Dear Team,
I have Cisco 4503 and I have inserted 1000BaseLH and light is not coming up but for 1000BaseSX its fine.
Please suggest.
CORE#show int GigabitEthernet1/18
GigabitEthernet1/18 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet Port, address is 001e.4aa6.b891 (bia 001e.4aa6.b891)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, Auto-speed, link type is auto, media type is 1000BaseLH
  input flow-control is off, output flow-control is off
  Last input never, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicast)
     0 packets output, 0 bytes, 0 underruns
     0 lost carrier, 0 no carrier
CORE#show inventory
NAME: "GigabitEthernet1/18", DESCR: "1000BaseLH"
PID: TRF5735AALB202    , VID: A1 , SN: OPA11241478
Thank You,
Abhisar.
3 REPLIES 3
Highlighted
Hall of Fame Guru
They require different fiber types. SX is designed for multimode while LH requires singlemode.
You also need compatible transceivers at the distant end.
Highlighted
Thanks Marvin,
It is solved.
https://supportforums.cisco.com/discussion/12464296/cisco-4503-1000baselh-sfp-light-not-coming-urgent
Thank You,
Abhisar.
Highlighted
Hall of Fame Community Legend
Duplicate post.
Go HERE.
