09-22-2020 11:32 PM
Dear All,
I just want to know which cisco 9200 switch supported module is use for connecting other devices ... sfp are commonly used as uplinks ... I want one sfp as uplink and rest of the three slots for endpoint devices (workstations)
09-23-2020 12:10 AM
What bandwidth? SFP or SFP+?
09-23-2020 12:36 AM
Dear Leo,
Thanks for your reply. Cisco 9200 supports following modules
. 4x1G ports that support 1G SFP modules.
• 4x10G ports that support either 1G SFP or 10G SFP+ modules.
• 2x25G ports that support SFP28 modules.
which one provides best solution, by the way I am looking for SFP+ 4x10G ports
09-23-2020 12:54 AM
C9200-NM-4X supports up to 4 x SFP/SFP+.
It all depends on what particular model you want:
09-23-2020 04:35 AM
Dear Leo,
Thanks for your reply. Please let me know which combo is suitable for my need as I mentioned earlier from 4 of the uplinks 3 are to be used for end devices (PCs) and one for uplink.
09-23-2020 05:06 AM
Sure if you buy 9200 with uplink Module has 4 ports
1 you can use uplink to parent switch or core.
3 ports you can use for other server purpose.
09-23-2020 05:17 AM
thanks for your reply... could you please share any link of cisco for my ref and understanding which module support it.
09-23-2020 05:35 AM
Look at the datasheet and supported modules, based on the model you choose in Cat 9200.
09-23-2020 04:52 AM
You did not answer my question.
All you gave me is "I need 4 x SFP+ ports". And what about the rest?
09-23-2020 05:06 AM
Sorry for the inconvenience, yes I need 4 x SFP+ but my question is may i use 3 of them as end device connection(PCs) and 1 as uplink port ??
