Connecting 3850-24S-S to 3850-12XS-S
hi guys
can i connect cisco 3850-24S-S by C3850-NM-2-10G network module with SPF module to cisco 3850-12XS-S and get 10Gb speed ?
i will use SFP 10Gb on both switch.
thanks
8 Replies 8
Leo Laohoo
Yes, this is possible.
thanks @Leo Laohoo
hi
is it possible to have mixed SFP Uplink ( one link is Single mode and one link be multi mode ) in one switch like 3850-24S-S ?
Not possible.
Both ends (including the fibre run) must be of the same wavelength.
hi
i think i did not explain well.
here is my links, each link has it's own end-to-end configuration.
3850 <--> 2960 :cable and modules are multi mode.
3850-A <--> 3850 : cable and modules are single mode.
Q: is it possible on 3850-A switch has both multi/single mode uplink ?
And what is the distance between the two 3850 running single-mode?
hi
3850 <---- 30m---->3850
3850 <----400m----> 2960
400 metre one, what speed are you planning to run on that?
What category of fibre optic run? OM3? OM4?
