05-08-2012 01:15 PM
Hello. We have many cisco 3560G switches running 12.2(46)SE. Several of the switches are on cwdm fiber links. We would like to be able to query the SFP's to see what their optical values are. I am told by a cisco optical person that I can use DOM commands to do this. I can't find the DOM commands. Does someone know if the DOM commands work on this specific switch, and if so, what are they and how do I use them?
Thanks.
05-08-2012 02:45 PM
Mike,
Does the command below work for you? Replace the gigabitethernet1/0/3 to the specifics based on your system layout.
show interfaces gigabitethernet1/0/3 transceiver detail
There are other transceiver commands which can be found here
scroll down a little bit until it shows "This is an example of output from the show interfaces interface-id transceiver properties command:
After that there are some other commands that might help you out.
Hope this helps.
Ryan
05-08-2012 08:06 PM
Ryan got the right commands to query an IOS switch-based optical transceiver with DOM capability.
One can also query it via SNMP.
