198
Beginner
Fabricpath best practice between DCs
Hi Guys,
We have 2 data centres and 2x Nexus 7K and 2x Nexus 5K per data centre. I want to implement fabricpath between Nexus 7Ks and Nexus 5Ks.
Can I implement fabricpath like connecting all 4 nexus 5K edges to all 4 nexus 7K spines or connect 2x nexus 5Ks to 2x nexus 7Ks in the same data centre and connect Nexus 7Ks in both data centres
What is the Cisco recommended solution. Thanks in advance
2 REPLIES 2
Highlighted
VIP Advocate
Re: Fabricpath best practice between DCs
check this design guide: https://www.cisco.com/c/en/us/products/collateral/switches/nexus-5000-series-switches/guide_c07-690079.html
Deepak Kumar,
Don't forget to vote and accept the solution If this comment will make help you!
Beginner
Thanks for your response.
I checked the URL before. I could not find the Cisco recommended fabricpath solution between 2 DCs.
Attached file has our high level network environment. Which option do you think is the Cisco recommended solution
Content for Community-Ad
August's Community Spotlight Awards
