10-07-2019 04:19 PM - edited 10-07-2019 04:23 PM
Hello there!
My network backbone currently consists of 1000BASE-SX links using OM2 multimode G50/125 µm fiber. The lengths are approximately 108 m / 98 m / 43 m / 40 m.
Now I'm supposed to upgrade to 10 Gigabit; what options do I have?
10GBASE-SR officially supports only 82 m over OM2 fiber. Is there any chance to work on 108 m? If not, what new cabling do you suggest?
I tend to switch to single mode fiber, since it seems to have fewer limitations in the long run.
Thanks!
Lucas.
Solved! Go to Solution.
10-08-2019 12:02 AM
You can use Cisco SFP-10G-LRM modules with mod-conditioning patch cables. These modules support up to 220m on OM2 MMF.
John
10-12-2019 09:16 PM - edited 10-12-2019 10:48 PM
@D8CE8FD5 wrote:
What new cabling do you suggest for being future-proof, say 100GBASE-*!?
1. The current standard for 40-/100 Gbps is OM3 & OM4 (up to 125 metres). Aim for OM4.
2. Check out the price of 100 Gbps optics. This is one reason why 100 Gbps is not "widely accepted" in non-telco/ISP network.
10-13-2019 08:53 PM
For future deployments, I would recommend you go with SM-fibre.
John
10-07-2019 04:41 PM
10-12-2019 04:31 PM
10-08-2019 12:02 AM
John
10-12-2019 04:26 PM
10-13-2019 08:53 PM
John
