04-01-2015 08:12 AM
GLC LH-SMD - 1000BASE -LX/LH SFP transceiver module, MMF/SMF will this supports Multimode & Single mode fiber channels ?
GLC-LH-SMD | 1000BASE-LX/LH SFP transceiver module, MMF/SMF, 1310nm, DOM |
04-01-2015 08:21 AM
Yes, as noted in the data sheet:
"The 1000BASE-LX/LH SFP, compatible with the IEEE 802.3z 1000BASE-LX standard, operates on standard single-mode fiber-optic link spans of up to 10 km and up to 550 m on any multimode fibers. When used over legacy multimode fiber type, the transmitter should be coupled through a mode conditioning patch cable. "
01-04-2019 05:41 PM
01-05-2019 06:02 AM
Picture 1 notes the transceiver meets the EXT (extended) temperature range specification.
Picture 2 notes the COM (commercial) specification.
I am not certain but suspect Picture 2 transceiver, manufactured in 7/2001 had not yet been certified compatible with the EXT specification as it was developed just around or after that time.
Once the specification was out and widely adopted, the part labeling was updated to reflect that it meets the more recent specification. (Picture 1 transceiver was manufactured in 6/2007.)
To know for absolute certainty we would have to get input from somebody involved in the product manufacturing. I can say that the two transceivers pictured are functionally the same.
11-20-2018 02:06 PM
