Highlighted
Beginner
GLC-LH-SMD
Hey everyone,
I have an odd situation here, 2 switches (3750X and 2960) connected with single mode fiber and using a GLC-LH-SMD SFP in each switch. When I check the DOM with 'show int gi0/1 trans det' (using the appropriate interface identifier for each switch), the 2960 end shows an optical transmit power of -5.1 and receive power of -20.0 (at the threshold for low warn). The 3750X end shows an optical transmit power of -5.5 and receive power of -5.0. At first I thought there was a fiber problem, but swapping the fibers didn't change the situation (and the fiber has been certified by the installers). I got an extra SFP and swapped it in, but that didn't make a significant difference either. Any ideas on how to troubleshoot this further, or possible causes?
thanks!
Everyone's tags (3)
10 REPLIES 10
GLC-LH-SMD
Hi Dave,
lets start by giving physical self loop on each interface, i mean connect Tx with Rx, use some 2-3dB attenuator if possible.
and will able to isolate if it is interface or the fiber.
Beginner
GLC-LH-SMD
Hi Sunil,
Thanks for the quick reply. We don't routinely work with single mode, most of our stuff is short haul so I don't have an attenuator. I can try and beg/borrow/steal one from somewhere, but wouldn't you think that if it was the fiber that when I swap tx/rx at both ends the problem should move with it (ie the other switch should show a degraded rx signal)?
GLC-LH-SMD
yeah by swapping fibers at both ends, if it was fiber than it should have moved.
i think you can try without attenuaotrs.
-5dBm will be ok for Rx.
Rising star
GLC-LH-SMD
What is the link length and the expected loss (per the documentation provided by installers)?  What makes up the link: how many splices and patch panels?
As suggested, I would loop at the ends to make sure the SFPs are funtioning properly.  No attenuator is necessary on the
GLC-LH-SMD SFP.
Beginner
GLC-LH-SMD
Thanks Tom et al, the link length is under 1000feet, I wasn't present when the link was installed so I'll have to review exactly what they did in terms of splices etc next time I'm on site. I don't have the documentation yet from the installers either, will get back to you on those points. I'll do the loop-back in the next day or two, once I'm on site and have dug up some SM fiber.
Beginner
GLC-LH-SMD
Update: tried the loop-back with both interfaces, and just to really make things interesting, there was no signal loss at either (Tx and Rx around the -5dBm to -7dBm). Put the installed fiber back in and the 2960 end again showed a degraded Rx close to -20dBm. I'm puzzled, any thoughts?
GLC-LH-SMD
Hi Dave,
than it looks it's because of some bad connector on fiber patch panel or some bad jumper somehwere,
you need to start with measuring power levels at each jumper/connector point and need to figure out.
all the best :-)
Beginner
GLC-LH-SMD
Thanks Sunil, sounds like a job for the installers . As far as I know, there are no breaks in the run anywhere except a splice box at either end (no patch panels, no other splices). I'm going to try the fiber swap test again, it must be a problem with one of the fibers, be nice to see it actually move with the fiber when I swap them!
GLC-LH-SMD
ok ..yeah something in fiber :-)
Rising star
GLC-LH-SMD
If there are not any patch panels at the ends of the fiber, did they just splice a fiber pigtail with connector on to the end of the between building fibers within the splice box?  I was going to say maybe a bad jumper, depending upon how you moved the fiber jumper cable at the SFP ports (or patch panel ports), but you don't have any jumpers.
Strange.
Content for Community-Ad
August's Community Spotlight Awards
