Can you please confirm this part "GLC-SX-MM - GE SFP, LC connector SX transceiver" is enough to connect two Cisco switches WS-C3750X-48PF-S with LC to LC Fiber multimode Optic Cable
Rgrds,
Alex
Could you clarify: "enough" of what?
This GLC-SX-MM transceiver can connect the two switches over multimode cable. The distance between the switches will depend upon the type of multimode fiber being used.
The SFP data sheet provides the above information. The compatibility documents will tell you which transceivers are compatible with your equipment.
I hope this helps!
Yes I confirm, given that the distance between both switches does not exceed 550 meters, if you want to have a 1.25Gbps uplink.
