GLC-SX-MM to GLC-SX-MM-RGD
Gandeleg.G
Hi guys,
We are planning to use 1552E APs with rugged SFP GLC-SX-MM-RGD. The switches are Cisco 3750X series.
1. It seems Cisco 3750X series do not support the rugged SFP GLC-SX-MM-RGD. Can anyone confirm this or has used the rugged sfp with 3750X?
2. If the 3750X doesn't support rugged SFP, we are planning to use GXC-SX-MM on the switch and the rugged on the AP side. Will this work?
Thanks in advance.
Delgee
Tom Randstrom
Using a GXC-SX-MM at one end and a GLC-SX-MM-RGD at the other will work.  They are both 1000Base-SX compliant transceivers.
The key is to confirm compatibilty between the transceiver module and the hardware it is being install in.
Leo Laohoo
Not supported.
Might work.
Thanks for the reply.
Tom Randstrom
Thanks for the confirmation. Much appreciated.
Delgee
