Highlighted
Beginner
GLC-SX-MM to GLC-SX-MM-RGD
Hi guys,
We are planning to use 1552E APs with rugged SFP GLC-SX-MM-RGD. The switches are Cisco 3750X series.
1. It seems Cisco 3750X series do not support the rugged SFP GLC-SX-MM-RGD. Can anyone confirm this or has used the rugged sfp with 3750X?
2. If the 3750X doesn't support rugged SFP, we are planning to use GXC-SX-MM on the switch and the rugged on the AP side. Will this work?
Thanks in advance.
Delgee
Everyone's tags (1)
1 ACCEPTED SOLUTION
Highlighted
Rising star
Using a GXC-SX-MM at one end and a GLC-SX-MM-RGD at the other will work.  They are both 1000Base-SX compliant transceivers.
The key is to confirm compatibilty between the transceiver module and the hardware it is being install in.
4 REPLIES 4
Highlighted
Hall of Fame Community Legend
Not supported.
Might work.
Highlighted
Beginner
Thanks for the reply.
Highlighted
Rising star
Highlighted
Beginner
Thanks for the confirmation. Much appreciated.
Delgee
