11-30-2011 01:32 PM
Ok. I've got ONS15310 with CTX2500 modules. Eqpt type STM16_PORT.
How do I know the STM Level?
Is it 16 or 64?
How can I find it out from Cisco Transport Controller?
Are there any other ways to figure it out?
Solved! Go to Solution.
12-01-2011 06:22 AM
Vannesa,
There are a couple of ways to do this in CTC.
1. node view ->Inventory
- the inventory window will show you what is in each slot
- Check the Eqpt Type and Actual Eqpt Type columns for the slot and port in question
2. From node view, double click on the CTX card to go to card view
- Card view->Provisioning->Pluggable Port Modules
- The left hand side of the window shows the Actual Equipment Type
- The right hand side shows the Port number and the Rate (STM16, STM64, etc.)
Hope this helps,
Steve Noyes
CSE Cisco TAC
12-01-2011 06:22 AM
Vannesa,
Hope this helps,
Steve Noyes
CSE Cisco TAC
12-01-2011 11:11 AM
That really helped. Thank you very much!
