10-21-2019 03:19 PM
Hi - I have an ASR903 that is using two QSFP_40GE_SR4 optics (both are recognized in the ASR903 on the appropriate ports) but the optics are not linking together when I connect them. I am using an MTP to MTP Female connector. I will upload an image of the jumper that I am using.
I should be able to link these together with no issue, correct? The routers are right next to each other < 150M distance limit that the optic has (and the jumper is just 2M).
TrivialPants
Solved! Go to Solution.
10-21-2019 07:20 PM
You may need to check the polarity of the cable assembly you are using to connect the two transceivers. The below link may help.
https://www.thefoa.org/tech/ref/testing/test/test-MPO.html
10-21-2019 07:20 PM
10-22-2019 10:25 PM
Hi Tom - I just wanted to say thanks. It was a polarity issue. The cables were pre-made MTP cables and the particular ones I was using were straight through ( not labeled as such, but I verified by checking the visual light coming out of the optic and the jumper)
The guide you provided really helps out. I need to read through it in more detail.
thanks!
