01-22-2021 06:02 AM
Hello Team,
ISL between Brocade X6-4 Director/6510 Switch through to 9132T Fabric Switch
Is it compatible/supported ?
I see no evidence, please advise..
01-22-2021 08:26 AM - edited 01-22-2021 08:26 AM
check with interoperability :
01-22-2021 02:11 PM
Cisco's ISL and Broadcom's (Brocade) ISL are the same in name only. They are both proprietary, if you need to connect a Cisco 9132 to a Brocade 6510, you need to use dot1q encapsulation.
That said, even on Cisco equipment, I hardly see ISL anymore. It is all dot1q.
Check the document below for reference:
