Ask the Expert- SD-WAN
387
Need Advise For Switches
HI All,
I am Planing to implement AVAYA IP PABX systems with 100 phones. Please advice me which Poe switches recommended for this network. Please note that DATA network already separated with different LAN network.
I will run only PABX network with this switches .All phones are POe.
Thanks.
5 REPLIES 5
Highlighted
Hall of Fame Community Legend
Re: Need Advise For Switches
2960S or 2960X.
NOTE:  I deliberately did not put Catalyst 9K.
HI ,
Thanks For quick response.
What about Cisco SG350 or 550.
Is there any issue with Cisco 9200L ..2960X going to end of life...Please advise.
VIP Advisor
Nothing wrong with Cat9200, Since you have mentioned only Voice and PoE, that is reason recomended for the low cost Switches.
BB
*** Rate All Helpful Responses ***
What about What about Cisco SG350 or 550...
VIP Advisor
they are small medium business, but they should work as expected, But check the specification and your requirement before you creating BoM.
BB
Content for Community-Ad
July's Community Spotlight Awards
