Ask the Expert- SD-WAN
656
Highlighted
Need Advise on 2 separate network switches
HI All,
Need Advice on below 2 networks which switch can be used
Data Network- 1 with 100 computer with 5 Servers  - Please advise which switch suitable ( 4 VLAN )
Voice Network 2 with 100 IP Poe Phones (Power comes From Poe Switch) - Please advise which switch suitable ( 1 VLAN)
Please note both Network 1 & 2 separate switches with separate RACK
I checked the price for 2960X and 9200L both price almost same. I.e. 9200L switch price is less but if I add C9200L Cisco DNA Essentials, 48-port, 3 Year Term license price & SNTC-8X5XNBD Catalyst 9200L 48-port data, 4 x 1G, Net  then the price is almost same with  2960X.
Do I need must purchase DNA Essentials, 48-port, 3 Year Term license price & SNTC-8X5XNBD Catalyst 9200L 48-port data, 4 x 1G, for 9200L Switch.
Without this essentials with the switch will work..
What about SG 500 Switches.
Please advice on this.
9200L poe & non poe Switch details:
C9200L-48P-4G-E -- Catalyst 9200L 48-port PoE+, 4 x 1G, Network Essentials
CON-SNT-C92004GE -- SNTC-8X5XNBD Catalyst 9200L 48-port PoE+, 4 x 1G, Net
C9200L-DNA-E-48-3Y -- C9200L Cisco DNA Essentials, 48-port, 3 Year Term license
2960 X poe & Non poe switch details:
WS-C2960X-48FPS-L -- Catalyst 2960-X 48 GigE PoE 740W, 4 x 1G SFP, LAN Base
1 REPLY 1
Rising star
Re: Need Advise on 2 separate network switches
@khajamujeebuddin786 hello,
HI All,
Do I need must purchase DNA Essentials, 48-port, 3 Year Term license price & SNTC-8X5XNBD Catalyst 9200L 48-port data, 4 x 1G, for 9200L Switch.  <<< it is for used for support or RMA process in case of physical failure.
Without this essentials with the switch will work..   << yes, switch will work normally
What about SG 500 Switches.   << today a i had SG550XG and works very well.
WS-C2960X-48FPS-L -- Catalyst 2960-X 48 GigE PoE 740W, 4 x 1G SFP, LAN Base   <<< i suggest it to you use for both case, today i used on my network all switch are this model and works very well.
Jaderson Pessoa
*** Rate All Helpful Responses ***
Content for Community-Ad
July's Community Spotlight Awards
