10-14-2010 05:25 AM
hello everybodey,
in my opinion I got a strange problem on my 3750 Switch:
2 Switches connected with each other and on only one switch I can see loggs about line protocol going up and down every 5 minutes.
on the other Switch I can't see any loggs about interface going up and down.
the switch is an 3750-12S with a 100/1000BaseSX SFP on it.
I'm a little bit lost here?
Thanks in advance
juergen
10-14-2010 07:04 AM
What does each of the transceivers show when issued the following command:
show interfaces interface-id transceiver detail
I am suspecting a possible dirty connector on one fiber that may be resulting in a low receive signal at one end of the circuit. If you swapped (switched) the fibers on both ends, does the problem continue or move to along with the fiber?
10-14-2010 07:38 AM
thanks baileyshbr for the fast response. Unfortunatly i can't execute the command show interfaces GiX/X/X transceiver detail.
In the meanwhile I changed the SFP incl the fibre to another free port and its stable now.
Any thoughts? I'm just curious about this problem. What does it mean if the log only show line protocol up / down but not the link itself.
thanks
10-14-2010 11:01 AM
Information pieced together from the web.
The Link LED indicates that the port is properly connected to a powered-on device. this LED is on when the Link Integrity Test (LIT) passes and off when the link integrity test fails.
The LINK LED is controlled by the Link Integrity Test, which determines the health of the link. Immediately after powerup, the physical medium attachment (PMA) transmits a normal link pulse (NLP) to tell the NIC at the other end of the link that this NIC wants to establish an active link connection:
•If the NIC at the other end of the link is also powered up, it responds with its own NLP.
•If the NIC at the other end of the link is not powered up, this NIC continues sending an NLP about once every 16 ms until it receives a response.
The link is activated only after both NICs are capable of exchanging valid NLPs.
So a cable can be just good enough to connect at the physical layer, but it corrupts packets as a result of subtle damage to the wiring or connectors. In your case, a dirty or damaged connector or jumper may have resulted in high data errors. The errors may not have been severe enough to stop the LIT to fail, but the Ethernet frames were being corrupted enough to cause the protocol to shut it down.
Hope this helps!
01-13-2019 12:41 AM
hi i had the same issue with my cisco 2811 the fa0/0 the line protocol is up and down for every 2 min please help me to solve it
