Highlighted
Beginner
ONS 15454 design
Saludos
Si estoy realizando un diseno de red en topologica de anillo, usando el CTP en version 9.2, el diseno esta conformado por 3 sitios, cual es la mejor opcion para agregar un servicio entre dos sitios quiero que este quede protegido a traves del tercer sitios, usar un p-ring demand o ROADMs?
gracias
Everyone's tags (2)
2 REPLIES 2
Highlighted
Beginner
ONS 15454 design
If you could post in English I may be able to help.
Highlighted
Rising star
ONS 15454 design
Using Google Translate...
Greetings
If I'm doing a topological network design ring, using the CTP version 9.2, the design is comprised of 3 sites, which is the best option to add a service between two sites want this it is protected through the third site , using a p-ring or ROADMs demand?
It would be helpful if the forum had customer support from in-region.
