Hello.
I had TCC3 cards with SW ons15454sdh.TDM.K9.R9211.pkg (454MSPP_SDH) - it is MSPP SW.
I upgraded this NE ( with 2 card TCC3) to ons15454.DWDM.K9.R930.pkg (454UTS_SDH) - it is MSTP SW.
Then I needed to be updated to ons15454sdh.TDM.K9.R9211.pkg (MSPP).
It was not possible via CTC...
Is it possible to update SW from the MSTP_software to the MSPP_software and back on the NE ?
After swap of the card I upgraded this card to SW ons15454sdh.TDM.K9.R9211.pkg (MSPP SW),
but CTC does not see the SDH cards (for example E1_42). Status card loading always.
However I see file (Application filename) *.BIN on the card TCC3 for the card E1_42.
What the procedure for loading files (*.BIN) from the card TCC3 to other cards through VxWorks ?
Thanks.
Open a Cisco TAC case to correct your issue. This would not be a standard procedure.
Sergey,
Tom is correct. There is a way to change from SDH to SONET or MSTP. However, this is not a normal operation, so it is not supported by CTC.
You need to open a TAC case for support. They can walk you through the procedure to convert from SDH to SONET or MSTP or vice-versa.
ok.
Thanks for your answers.
I open the case a TAC next week.
I think it is a normal operation for VxWorks.
When change software from SDH to SONET or MSTP, we change only the files of *.BIN on the TCC flash.
(I could be wrong)
version of VxWorks 5.4 does not change. ( this is exactly)
If I find the procedure for loading files (*.BIN) from the card TCC to other cards through VxWorks I can do all manually.
