08-01-2016 02:31 AM
Good day,
I have Cisco 2911 (EHWIC-1GE-SFP-CU , GLC-SX-MMD, LC to SC Adapter. I want to configure PPPOE on cisco SFP port as diagram bellow:
Cisco R2911 (SFP Port) ---- (SC - LC Adapter) --- ISP
interface Dialer1
ip address negotiated
ip mtu 1452
ip nat outside
ip virtual-reassembly in
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
ppp authentication chap pap callin
ppp chap hostname XXXX
ppp chap password 0 XXXX
ppp pap sent-username XXXX password 0 XXXX
ppp ipcp dns request
interface GigabitEthernet0/0/0
no ip address
media-type sfp
pppoe enable
pppoe-client dial-pool-number 1
I had checked Dialer1 (up up ), GigabitEthernet 0/0/0 (down down), Fiber Cable (working) >>> It doesn't work
Anyone can help me how to fix this problem.
Thank you so much
Sang
Solved! Go to Solution.
08-01-2016 04:25 AM
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/gigabit-ethernet-gbic-sfp-modules/product_data_sheet0900aecd8033f885.html
Table 1. SFP Port Cabling Specifications
08-01-2016 04:25 AM
08-01-2016 08:43 AM
Hello kayukovvalera,
Thank you for helping. I had called for ISP to check what are their fiber mode using yesterday? They answered "It's Single Mode" then I had bought SMF Cable and it's not worked. If I change SMF to MMF cable as your suggest and is it worked with ISP Single mode ?
Thank you so much.
Sang
