09-08-2019 07:29 AM
is my QSFP-40G-SR4 OK with OM4 fiber MPO connector cause Link length supported OM4 is not mentioned under interface transceiver information,
transceiver is present
type is QSFP-40G-SR4
name is CISCO-LUMENTUM
part number is JQPR04SRAB2NFCS
revision is 01
serial number is xxxxxxxxxxx
nominal bitrate is 10300 MBit/sec per channel
Link length supported for 50/125um OM2 fiber is 30 m
Link length supported for 50/125um OM3 fiber is 100 m
cisco id is --
cisco extended id number is 16
cisco part number is 10-2672-03
cisco product id is QSFP-40G-SR4
cisco vendor id is V03
Solved! Go to Solution.
09-08-2019 07:22 PM
Yes it is supported with OM4 fiber:
"The Cisco 40GBASE-SR4 QSFP Modules support link lengths of 100 meters and 150 meters, respectively, on laser-optimized OM3 and OM4 multimode fibers. It primarily enables high-bandwidth 40G optical links over 12-fiber parallel fiber terminated with MPO/MTP multifiber female connectors. It can also be used in a 4x10G breakout mode for interoperability with 10GBASE-SR and SFP-10/25G-CSR-S (in 10G mode) interfaces up to 100 and 150 meters on OM3 and OM4 fibers, respectively."
09-08-2019 07:22 PM
09-09-2019 03:43 AM
