Recommended SFP for 1000base-LH upgrade to 10G
Little Bunny
Hello
We're going to be upgrading a 1G fiber link to 10G. Currently the SFP type in both ends is 1000base-LH. What would be the equivalent 10G SFP required to upgrade and will the cabling itself be compatible?
LB
currently, you are using:
1000BASE-LH which is 1310nm and uses Single Mode Fiber,
so for 10Gig you can use:
Cisco SFP-10G-LR
Cisco SFP-10G-LR-S
both are compatible with Cisco Nexus 9000 series and are using 1310nm and single mode fiber.
both these 10G pluggable are easy to obtain very generic :-)
7 Replies 7
johnd2310
Level 8
Level 8
The SFP-10G-LR module should be the equivalent 10G module . https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/data_sheet_c78-455693.html?dtid=osscdc000283
John
**Please rate posts you find helpful**
Thanks John. Just to confirm, SFP-10G-LR and not SFP-10G-LRM?
Also, to add to this...would the SFP-10G-SR be compatible? They seem to be a lot cheaper!
The existing cable between the two Nexus devices is a yellow single-mode cable.
supoonia
whats the name of the equipment or the card which you going to upgrade.
The fiber link we're upgrading is between two Nexus 9ks
Cisco SFP-10G-LR
Cisco SFP-10G-LR-S
Hi supoonia
Thanks for the info. Would the SFP-10G-LRM also be compatible? They seem to be much cheaper than the SFP-10G-LR or SFP-10G-LR-S and are also SMF 1310nm.
Cheers
LB
supoonia
please find the 10G compatibility matrix.
https://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/10GE_Tx_Matrix.html#_Toc510727797
SFP-10G-LRM is supported in Nexus 9000 series, the only limitation is its reach is very short, only 300m.
