648
Highlighted
Beginner
replacement air filter for 15454-M6-AC
The following Hardware installation guide states taht the air filter on the 15454-M6 AC power supply is replacable, but I cannot find a part number for a customer wanting them.
http://www.cisco.com/c/en/us/td/docs/optical/hardware/15454install/guide/hig15454/hig_15454M6.html#pgfId-824180
"The fans cool the module and guarantees proper operation across the complete operating temperature or output power range. These fans contain replaceable air-filters. The AC power module draws power from the power lines to turn on the ONS 15454 M6 shelf. See Table A-3 for the power specifications of the AC power modules."
 If anyone has a cisco or non cisco part number I can give my customer, I would appreciate it.
-mike
CCIE# 6771
1 ACCEPTED SOLUTION
Rising star
I found the part number of on
I found the part number of on Cisco's ordering page. Not easy to find.
15454-M6-AC-FLT=
6 service slot MSTP chassis AC power supply fan filter
4 REPLIES 4
Rising star
The 15454 M6 data sheet ,
The 15454 M6 data sheet , listed in Table 7: Ordering Information, indicates the part number for the fan tray filter for the M6 chassis is "15454-M6-FTF".
Beginner
That is the Fan Tray filter,
That is the Fan Tray filter, I have already put that on the customer BoM, we are looking for the filter for the AC Power supply.
-mike
CCIE# 6771
Rising star
15454-M6-AC-FLT=
I hope the jpg file helps you
I hope the jpg file helps you.
If it doesn't, you can contact me
Content for Community-Ad
July's Community Spotlight Awards
