06-22-2015 04:41 AM
Hi all,
two queries I cannot find an answer for:
1. is the SFP-10G-LR compatible with the ASR 1002 router?
2. And if so, can it run at 1gig or is it just fixed at 10gig?
Paul
Solved! Go to Solution.
06-22-2015 05:04 AM
10 Gbps.
Yes.
06-22-2015 05:04 AM
10 Gbps.
Yes.
06-22-2015 05:17 AM
Great thank you.
Is there any good one stop webpage that details Cisco SFPs specifications?
Paul
06-22-2015 07:40 PM
Not one - that would be too easy. :)
For a given transceiver class (e.g. 10 Gbps) see the respective:
About half the questions posed on this sub-forum can be answered with a careful reading of those.
