SFP-10G-LR-S is not recognize, C9300-NM-8X (8x10G Uplink Module)
weujo1
Could someone help on this?
SFP-10G-LR-S is not recognize by my brain new switch.
Hardware: C9300-48P-e
Module: C9300-NM-8X (8x10G Uplink Module)
IOS VER: Version 16.8.1r [FC4]
Don't know why and what to do. need to install my system tomorrow.
Please help.
9 Replies 9
balaji.bandi
have you check the comptability matrix ?
https://tmgmatrix.cisco.com/home
BB
Hi Balaji,
I checked and it said that it is compatible. That why we bought that.
Don't understanding what is wrong.
show you post the configuration and show inteface status / show interface  x/x
BB
Leo Laohoo
Console into the switch and reboot.  Post the entire bootup process.
Post the complete output to the command "sh interface <PORT> trans detail".
And be ready to raise a TAC Case because I suspect this is CSCvj74744.
Another option is to upgrade the firmware.
//////////////////////////////////////////////////////////SHOW Running/////////////////////////////////////////////
Stack1#show running-config
Building configuration...
Current configuration : 20432 bytes
! Last configuration change at 16:50:59 EST Fri Feb 8 2019 by admin
! NVRAM config last updated at 16:53:27 EST Fri Feb 8 2019 by admin
version 16.8
no service pad
service unsupported-transceiver
no platform punt-keepalive disable-kernel-core
hostname Stack1
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
****************Interface Config***********************
interface Port-channel1
description Uplink 20Gbps
switchport mode trunk
interface TenGigabitEthernet1/1/1
description EthChan
channel-group 1 mode active
interface TenGigabitEthernet2/1/1
description EthChan
control-plane
service-policy input system-cpp-policy
mac address-table notification mac-move
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
///////////////////////////////////////////////////Show interface status/////////////////////////////////////////
Port Name Status Vlan Duplex Speed Type
Te1/1/1 UplinkA 20Gbps connected trunk full 10G SFP-10GBase-SR
Te1/1/2 UplinkB 20Gbps notconnect 1 auto auto unknown
Te1/1/3 notconnect 1 auto auto unknown
Te1/1/4 notconnect 1 auto auto unknown
Te1/1/5 notconnect 1 auto auto unknown
Te1/1/6 notconnect 1 auto auto unknown
Te1/1/7 err-disabled 1 auto auto unknown
Te1/1/8 notconnect 1 auto auto unknown
Te2/1/1 UplinkA 20Gbps connected trunk full 10G SFP-10GBase-SR
Te2/1/2 UplinkB 20Gbps notconnect 1 auto auto unknown
Te2/1/3 notconnect 1 auto auto unknown
Te2/1/4 notconnect 1 auto auto unknown
Te2/1/5 notconnect 1 auto auto unknown
Te2/1/6 notconnect 1 auto auto unknown
Te2/1/7 notconnect 1 auto auto unknown
Te2/1/8 notconnect 1 auto auto unknown
Po1 UplinkA 20Gbps connected trunk a-full a-10G N/A
Po2 UplinkB 20Gbps connected trunk a-full a-10G N/A
//////////////////////////////////////show interfaces Te1/1/2//////////////////////////////////////
TenGigabitEthernet1/1/2 is down, line protocol is down (notconnect)
Hardware is Ten Gigabit Ethernet, address is d4ad.7136.2d36 (bia d4ad.7136.2d36)
MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
Keepalive not set
Auto-duplex, Auto-speed, link type is auto, media type is unknown
input flow-control is off, output flow-control is unsupported
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
///////////////////////////////////////////show interfaces Te1/1/2 transceiver detail//////////////////////////////
Diagnostic Monitoring is not implemented.
on high level
Auto-duplex, Auto-speed, link type is auto, media type is unknown   <-- is this something can address ?
BB
Not sure to understanding. Could you please, eloborate more?
Post the complete output to the command "sh int statu err".
"sh int statu err" does not return any data.
