03-31-2015 06:21 AM
Ciao,
is there anyone that can explain what is (are) the difference(s) between the two optics in the title ?
In particular what are the "unnecessary features" of the SFP-10G-LR-S ? Can they be used in UA to Core deployment ?
(http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/bulletin-c25-733742.html)
BR,
Luciano
Solved! Go to Solution.
03-31-2015 06:32 AM
The table below shows the key feature differences for the 10 Gbps S-class vs. C-class.
For UA to core campus applications, S-class are quite suitable.
C-Class | S-Class | |
Multi-rate vs Single-rate | Multi-rate optics:
| Single-rate optics:
Operating temperature range |
03-31-2015 06:32 AM
| Single-rate optics:
03-31-2015 07:27 AM
Dear Marvin,
thanks for you kindly replay.
May I ask you where did you find the above table ?
BR,
Luciano
03-31-2015 07:32 AM
You're welcome.
It is from an FAQ developed internally at Cisco and provided to the partner community to assist in product presales positioning.
If it answers your question, please mark as such. Thanks.
05-30-2016 10:52 AM
Hi Team,
Can anyone support if N3548 support 10G classic transceivers (SFP-10G-LR-S=)?
Neeraj
05-30-2016 11:20 AM
They are not listed as supported in the compatibility matrix.
08-01-2016 12:33 AM
Please note that the S Class SFP's doesn't support FCoE.
05-23-2019 12:56 PM
how do you tell when looking at the part number if it is S class or C class or can you even do that. If not where is the class specified per part number in the data sheet?
05-23-2019 06:54 PM
S class transceivers have "-S" at the end of the SKU (Stock Keeping Unit, also known as part number).
SFP-10G-SR = most common non-S-class 10 Gbps transceiver
SFP-10G-SR-S = S-class version of the same
To check compatibility with your equipment, use this tool:
11-17-2015 12:11 PM
I was wondering the same thing. I'm looking for SFP+ modules to go from core to building distribution switches, and the cost of migrating from 10G X2 modules to SFP+ is insane!!
06-02-2016 01:51 AM
The Cisco S-class optics is compatible with non s-class optics, except that S-class optics has different temperature ranges.
And if you want to replace the X2 module with original SFP+ module, the total cost is high, but you can find a OEM vendor to help you out. I have bought compatible Cisco SFP+ modules from Fiberstore for just $16. You can have a try !
