Highlighted
SFP-10G-LR-S vs SFP-10G-LR
Ciao,
is there anyone that can explain what is (are) the difference(s) between the two optics in the title ?
In particular what are the "unnecessary features" of the SFP-10G-LR-S ? Can they be used in UA to Core deployment ?
(http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/bulletin-c25-733742.html)
BR,
Luciano
Everyone's tags (1)
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Guru
The table below shows the key
The table below shows the key feature differences for the 10 Gbps S-class vs. C-class.
For UA to core campus applications, S-class are quite suitable.
C-Class
S-Class
Multi-rate vs Single-rate
Multi-rate optics:
  • Ethernet
  • OTN
  • WAN-PHY
Single-rate optics:
  • Ethernet only
Operating temperature range
  • Commercial (0C to 70C)
  • Extended (-5C to 85C)
  • Industrial (-40C to 85C)
  • Commercial (0C to 70C) only
10 REPLIES 10
Highlighted
Hall of Fame Guru
C-Class
S-Class
Multi-rate optics:
  • Ethernet
  • OTN
  • WAN-PHY
Single-rate optics:
  • Ethernet only
Highlighted
Dear Marvin,thanks for you
Dear Marvin,
thanks for you kindly replay.
May I ask you where did you find the above table ?
BR,
Luciano
Highlighted
Hall of Fame Guru
You're welcome.It is from an
You're welcome.
It is from an FAQ developed internally at Cisco and provided to the partner community to assist in product presales positioning.
If it answers your question, please mark as such. Thanks.
Highlighted
Beginner
Hi Team,
Hi Team,
Can anyone support if N3548 support 10G classic transceivers (SFP-10G-LR-S=)?
Neeraj
Highlighted
Hall of Fame Guru
They are not listed as
They are not listed as supported in the compatibility matrix.
Highlighted
Beginner
Please note that the S Class
Please note that the S Class SFP's doesn't support FCoE.
Highlighted
Beginner
Re: The table below shows the key
how do you tell when looking at the part number if it is S class or C class or can you even do that. If not where is the class specified per part number in the data sheet?
Highlighted
Hall of Fame Guru
S class transceivers have "-S" at the end of the SKU (Stock Keeping Unit, also known as part number).
SFP-10G-SR = most common non-S-class 10 Gbps transceiver
SFP-10G-SR-S = S-class version of the same
To check compatibility with your equipment, use this tool:
https://tmgmatrix.cisco.com/
Highlighted
Beginner
I was wondering the same
I was wondering the same thing. I'm looking for SFP+ modules to go from core to building distribution switches, and the cost of migrating from 10G X2 modules to SFP+ is insane!!
Highlighted
The Cisco S-class optics is
The Cisco S-class optics is compatible with non s-class optics, except that S-class optics has different temperature ranges.
And if you want to replace the X2 module with original SFP+ module, the total cost is high, but you can find a OEM vendor to help you out. I have bought compatible Cisco SFP+ modules from Fiberstore for just $16. You can have a try !
