03-29-2017 03:00 PM
Hi everyone
I'm trying to connect one Cisco Nexus 5548UP with a SPF 10G-LR to a one Cisco Cat 6506-E with a X2-10G-LX4 with a MMF but the connection do not goes up, I think the 10G-LR works in the same wavelength of 1300-nm, any clue about this?
I guess I need a 10G-LR-X to in the side of the nexus =(
Thanks in advance
Solved! Go to Solution.
03-29-2017 08:58 PM
The LX4 interface actually uses four (4) data streams (wavelengths) across each of the two MMF fibers. See Table 2 here:
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/10-gigabit-modules/product_data_sheet0900aecd801f92aa.html
It is not compatible with the more commonly used 10Gbase-LR which only use a single wavelength per fiber.
03-29-2017 08:58 PM
03-30-2017 09:01 AM
Thanks Marvin
That is really sadly right...
We need to change the LX4 with another kind of X2
