1244
Highlighted
Beginner
SFP-10G-LRM compatible?
I want to perform upgrades part by part and would like to know if I
Can I connect a SFP-10G-LRM to a GLC-LH-SM 1gb interface over OM1 fiber atleast until I upgrade the core side of the network and the under ground fiber?
1 ACCEPTED SOLUTION
Highlighted
Rising star
Unfortunately, optical transceiver modules do not auto negotiate for speed.  Therefore, you cannot connect a 10Gbps interface to a 1Gbps interface.  You need to upgrade both ends before the circuit can be completed.
If you need equipment to support the intermediate step in the upgrade cycle, you might look at purchasing Cisco Refurbished Products.
2 REPLIES 2
Highlighted
Rising star
Highlighted
Thank you for the fast reply.
