08-12-2019 11:57 PM
I check and got advise with a Cisco partner, they had suggested to use SFP-10G-SR for my C2960XR-48FPS.
Had encountered the switch is not detecting the SFP module.
The model is always "Unknown".
Want to know if the SFP is compatible wit hmy switch though the partner may have made a mistake.
08-13-2019 12:01 AM - edited 08-13-2019 12:03 AM
check the compatable matrix :
and good matrix and explanation :
https://ciscodatasheet.blogspot.com/2017/08/supported-sfp-modules-for-cisco-2960-x.html
08-13-2019 12:23 AM
08-14-2019 01:54 AM
Thank you all.
Learned about the incompatibility given my newbie for SFP module.
Going need source a new switch to support this SFP module.
08-14-2019 08:27 AM
yes, that is the reason while doing BoM need to cross check before we buy
if found the solution mark as solved.
08-18-2019 12:38 AM
C2960XR-48FPS-L support 1G SFP only you can use GLC-SX-MMD for multimode and GLC-LH-SMD for singlemode,
If you wish to use SFP-10G-SR you need to change the switch to C2960XR-48FPD-L
hope this was helpful
