902
Beginner
SFP-10G-SR unknown on C2960XR-48FPS-L
I check and got advise with a Cisco partner, they had suggested to use SFP-10G-SR for my C2960XR-48FPS.
Had encountered the switch is not detecting the SFP module.
The model is always "Unknown".
Want to know if the SFP is compatible wit hmy switch though the partner may have made a mistake.
5 REPLIES 5
VIP Advisor
Re: SFP-10G-SR unknown on C2960XR-48FPS-L
check the compatable matrix :
https://tmgmatrix.cisco.com/
and good matrix and explanation :
https://ciscodatasheet.blogspot.com/2017/08/supported-sfp-modules-for-cisco-2960-x.html
BB
*** Rate All Helpful Responses ***
Hall of Fame Community Legend
2960XR-48FPS doesn't support SFP+.
The model number doesn't have a "D".
Beginner
Thank you all.
Learned about the incompatibility given my newbie for SFP module.
Going need source a new switch to support this SFP module.
VIP Advisor
yes, that is the reason while doing BoM need to cross check before we buy
if found the solution mark as solved.
BB
Beginner
C2960XR-48FPS-L support 1G SFP only you can use GLC-SX-MMD for multimode and GLC-LH-SMD for singlemode,
If you wish to use SFP-10G-SR you need to change the switch to C2960XR-48FPD-L
hope this was helpful
Content for Community-Ad
July's Community Spotlight Awards
