SFP Low Signal Levels?
Hi all,
hope to find everyone in these troublesome times
It;s the following, I have a Cisco 3650 and a Cisco 2960 joined by single mode fiber and when doing a "show interface transceiver details" I see this:
High Alarm High Warn Low Warn Low Alarm
Temperature Threshold Threshold Threshold Threshold
Port (Celsius) (Celsius) (Celsius) (Celsius) (Celsius)
Te1/1/2 31.1 93.0 88.0 -43.0 -48.0
Te1/1/3 40.6 100.0 95.0 -40.0 -45.0
Voltage Threshold Threshold Threshold Threshold
Port (Volts) (Volts) (Volts) (Volts) (Volts)
Te1/1/2 3.29 3.63 3.49 3.10 2.97
Te1/1/3 3.29 3.60 3.50 3.00 2.90
Current Threshold Threshold Threshold Threshold
Port (milliamperes) (mA) (mA) (mA) (mA)
Te1/1/2 40.2 85.0 80.0 20.0 15.0
Te1/1/3 12.7 90.0 80.0 2.0 1.0
Optical High Alarm High Warn Low Warn Low Alarm
Transmit Power Threshold Threshold Threshold Threshold
Port (dBm) (dBm) (dBm) (dBm) (dBm)
Te1/1/2 -1.6 2.5 1.4 -9.2 -10.1
Te1/1/3 -6.6 -1.0 -2.0 -11.0 -12.0
Receive Power Threshold Threshold Threshold Threshold
Te1/1/2 -40.0 2.5 1.4 -15.4 -16.4
Te1/1/3 -23.6 4.9 2.9 -28.2 -30.0
The port TE1/1/2 is offline and not working, and what bothers me is the values on the receive. This is a 1Gbps link and for what I saw and understand this signal is too low.
In this link I'm having loads of output drops from the access switch to the core switch and I assume this is the cause.
Am I correct in assume that?
Thank you
2 Accepted Solutions
It all depends on cable what Fibre cable is this? OM3 /4 ? so distance matters. is ths multi-mode or single-mode cable ?
regarding power level, if the port is shutdown you see the expected results. ( again based on cisco SFP experience, if the SFP compatible non-cisco, you need to refer the vendor document.)
example discussion for power level can be found here and useful.
https://community.cisco.com/t5/optical-networking/understanding-tx-rx-light-level/td-p/2794532
BB
It would seem that there may be an issue with the fiber link; dirty connectors, excessive fiber bends.  If you have a power meter and light source, you could test the fiber link's attenuation (loss).  It will help you determine if it is a problem with the fiber link or a transceiver module issue.
Forgot to mention, the modules being used are Startech Cisco compatible 1000BASE-LX/LH SFP Single mode modules and the run of fiber cable between the Core Switch Cisco 3650 and the 2960 is from a first floor to a sixth floor of the building... I would say around 100 meters...
BB
Thank you very much for the reply.
Meanwhile I swapped the sfp modules in both ends but to no avail.
I know the fiber is being rejoined in three places until it reaches the core switch. I will have to investigate all those...
